Letter 25040
Acid bright dip problems
Hai, I have some problems about acid bright dip.
1. why the aluminium in acid bright dip go up very quickly to 50
g/L in about 2 weeks from 39 g/L? What are the factors that determine
the rate of dissolution of aluminium?
2. why some aluminium metals especially from china has to be caustic
dip for a while before going to the bright dip? or else it will cause
excessive pitting?
3. except adding more ammonium sulphate as a fume suppresant, is
there anything else that we can use to actually the fume quite
significantly? as adding more ammonium sulphate does not actually
help properly.
4. what is the average rate of dissolution of aluminium per sq meter
against the rate of drag out?
5. what is the recommended usage of acid bright dip per sq meter in a
10,000 litres tank?
6. is it possible to let the aluminium that has been dissolved in
acid bright dip to sttle out for some time and reuse the top part of
the acid mix with fresh acid bright dip?
Any answer would be very much appreciated. Thank you very much?
Joe Yefrey
chemical company - Melbourne, Victoria, Australia
Hi,
I recomend u to look for book :
Technology
of Anodizing (SHESBY).
Hadi Khosravi
- Tehran, Iran
Hi Joe,
I'm using an Alupol IV from 23 years without any problem about the
quantity of dissolved aluminium But what is your work temperature and
what is the density of your bath ? Those 2 parameters are very
important for the stabilisation of the dissolved aluminium.
Paul Moreau
aluminum reflectors for lighting - Liège, Belgium
Hi Joe,
Is there a possibility that your Ammonium Sulphate suppressant is
causing pitting? Apparently the suppressant for Chrome (probably an
entirely different chemical) does lead to pitting, so I'm told.
Re fuming ... ah, I've seen mega fuming during Bright Dip
operations, par for the course, I thought.
There is a solution (ie. an answer NOT a chemical!) and that lies
in the critical design of the fumehood system to prevent but capture
the billowing emission clouds ... I believe that in Melbourne you
have people who can solve that.
Freeman Newton
- White Rock, B.C. Canada
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- Post a new
question or inquiry on a different subject.
