Chemistry of aluminum surface
Can anyone supply any information about the nature of a pure aluminium surface (that has not seen any oxygen or water) and then subjecting it to the following:
1. Immersed in water, rinsed and dried
2. Dipped into nitric acid,rinsed and dried
3. Dipped into caustic, rinsed and dried.
Does a different oxide or hydrated oxide form in each case? Can someone recommend a good reference book for the surface chemistry of aluminum?
Thanks in advance for your help.
Pat Mentone
Pat Mentone
St Paul, Minnesota
Well, I have been researching on making organic-inorganic hybrid coatings on aluminum surfaces. So far from my experience, aluminum forms a tenacious aluminum oxide layer on the surface. Nitric acid has no effect on this oxide layer. However with caustic aluminum oxide gets converted to aluminum hydroxide Al-OH.
Jaspreet Singh Gandhi
- Cincinnati
