PAINTING GALVANIZED STEEL
WHAT DOES THE METALLIC-PHOSPHATE PROCESS CONCERNING THE PAINTING OF HOT DIP GALVANIZED MILD STEEL CONSIST OF. WHAT TYPE OF CHEMICALS ARE USED AND WHAT ARE THE PARAMETERS OF THIS PROCESS.
THANKS,
James Campbell
structural steel fabrication - Ft Worth, Texas
Hi James,
It is quite typical to use zinc phosphating as the pretreatment for HDG. The process parameters are wide-ranging, however, depending on the application.
George Gorecki
- Naperville, Illinois
