Surface roughness
I would like to know the method of checking the surface roughness on the spherical rubber material of 10 mm diameter.
THAMBIDORAI Vair brakes manufacturer - CHENNAI, TAMIL NADU, INDIA
10 mm is kind of small, but you can probably get a reading from a profilometer if you fix the meter point and rotate the ball under it.
AF Kenton
