Chrome redipping for wheel
RFQ: Where can I get a set of 20" wheels re-dipped?
Wayne Dameron- Warsaw
January 14, 2023
privately respond
to this RFQ ⇧
Ed. note: As always, gentle readers: technical replies in public and commercial replies in private please (huh? why?)
A. Hi Wayne
Because it is so expensive to do real chrome plating on alloys wheels at low volume, and peeling happens if things aren't perfect, it is hard to be in that business; I suspect there are only a half-dozen shops in the country who do aftermarket plating of alloy wheels, almost surely not more than a dozen. Google will find them with "need chrome plating of alloy wheels". Go to the listed shops (ignore the supposed compilation sites, as they will probably take you more time than they're worth). Such shops also sometimes advertise in Hemmings Motor News.
This is probably a good application for chrome-look paint, sometimes called 'spray chrome', as an alternative to real chrome plating.
RFQ: I just bought a set of chrome rims and I need to re-dip one of them. I don't know where to take it or to get it redipped?
Please help me.
Denny Kneifel Jr.automotive - LaPorte, Indiana
A. We printed your inquiry, Denny, but the bad news is that redipping will probably cost more than a replacement wheel. Chrome plating is a very labor intensive process requiring, among other things, custom fabrication of auxiliary anodes to match the wheel shape. When thousands of identical wheels are plated, the plating cost can be moderate. When just one must be plated, the labor cost can be outrageous.
go to Introduction to Chrome Plating
RFQ: Looking for a reputable shop to re-chrome C5 Corvette thin spoke wheels in the New Orleans area.
Jai Sevinhomeowner - Raceland, Louisiana, USA
RFQ: Can you have aluminum wheels chrome dipped? And will it look the same as original chrome wheels?
David WhalenDurand, Michigan
A. Yes, David. They will look the same because they will be the same (allowing for differences in quality from shop to shop). But they will be very expensive because it costs a lot more to chrome plate things onesy-twosy than to chrome plate them hundreds at a time.
