+++ I am considering using galvanized sheet metal for my kitchen countertops and backsplash and need to learn about caring for the surface. What sort of sealants, oils, or waxes will prevent staining from foods and spills? Nancy B [name
deleted for privacy ]
+++ I have the exact same question as a previous inquirer, but I didn't see an answer to her question. Maybe you can answer for me: I am interested in having a zinc metal countertop put in my kitchen and would like an antique finish applied (distressed). Can you tell me how you distress a zinc countertop to make it look decades old and what is the upkeep on them? Any info is helpful. Lori B [name
deleted for privacy]
++++ We are so very interested in anyone having any info. about zinc countertops. How to get them, who will fabricate them,...and how to age them! We have a Tudor style 1917 home, we want the old sinks and appliances back, and aren't the least bit interested in granite. We are grateful for any info. (P.S. I believe there are zinc countertops with brads on the edges in the movie "Meet the Fockers"---these are what we want and believe belong in certain areas of our kitchen.) We live in Omaha Ne. Happy to share any serious restoration resources we have accumulated! Thank you, Maggie and Matt Maggie J [name
+++++ I am looking for a new zinc countertop, having had one in a rental house years ago and liked it very much. I used Vim/Ajax/Comet to clean although it probably is not recommended it did not damage it in any way. I found a link regarding care at soupcan.com/zincfaq.html Hope this is helpful to someone. Theresa B [name
RE: ZINC METAL COUNTERTOP - DISTRESSING I tried to find an answer to the various questions on how to distress a zinc metal countertop; perhaps I am not looking in the right area. I am very interested in knowing how I can accomplish this myself. The zinc sheet is a blue grey currently. I want to distress/age it - very much so. I understand various acids, i.e. vinegar, etc. will do this. I would like to know and would greatly appreciate any food safe suggestions you may have. Thank you, Mona F [name
+++++ Kelly, Nancy: I think solid zinc metal is considered safe (see the link suggested by Theresa). However, I do not think galvanized metal is safe unless you are quite confident of its origin. Galvanized metal is steel (magnetic) sheet that has been dipped in molten zinc and often has a chromate conversion coating (read that as hexavalent chromium) -- I wouldn't use it for a food surface. Lori: This page is a public forum. When any reader chooses to respond, their response will be added; sorry that there are limited answers so far, but there's no secret hiding place with the responses :-) Theresa: Thanks for the link; I think it answers most of the questions on this page. Readers can also see nice photos of zinc countertop installations at that site. Mona: The blue-grey color, and some miscellaneous scratches that your zinc may suffer, probably already comprises the distressed look for zinc. You could try 'painting' it with as strong a solution of table salt as you can get (basically wet salt) and see what darkness that adds, but zinc doesn't turn green & brown like, for example, copper or brass.
+++++ RE: ZINC - DISTRESSING Through experimenting on a piece of zinc for a countertop, using different types of food safe acids, ie., vinegar, lemon, I have so far found, tomatoes (from a can) to be the most distressing. Mona F [name
+++++ To Maggie J (and all others!) Toni M [name
+++++ To Toni M, Bill R [name
+++++ Toni and everyone. Maggie J [name
+++++ You can get solid zinc surface tiles and Vcap trim at Columbia metal products in California For around $80 per square foot it installs as easy as regular ceramic tile and looks great! Steve H [name
April 11, 2006 You can make your own zinc countertops. There are several sources of zinc sheeting on the Internet. My wife and I made our own huge zinc-covered kitchen island and backsplashes. Make the substrate from MDF or particleboard like you would for any laminate. Cut the zinc sheet to approximate size by scoring with a utility knife like you would laminate or use shears for little pieces. Glue it with contact cement, same as for laminate and roll it down really good with a J roller. The edges are then trimmed with your router and a laminate blade. This makes a big mess just like laminate! Soldering is tricky but the supplier sells zinc solder and flux. You will need to use a really big soldering iron! Use a sander to grind the welds, to remove the mill oxide and to achieve the level of finish you want. Because Zinc is a reactive metal it cannot be permanently painted, (except maybe with epoxy), but after you sand it, it will take clear Krylon, for example. Coatings will not work in a wet area. Clear wax is OK but must be laboriously re-applied periodically. Zinc will be very affected by kitchen liquids including water. Discolorations can be rubbed away with a scotchbrite pad and some powdered cleanser. Because zinc sheets only come one meter wide, when making your countertop you may encounter a need for a butt joint. You can leave a hairline seam, which looks OK, or devise some kind of solder joint with a recessed backing strip. Another cool thing about zinc is that you can very easily make attractive patterns in it with a sanding block, for example if you want to make inserts for your appliance front panels, before you clear coat it. James M [name
April 19, 2007 I had zinc countertops installed in Oct.06. I want to tell anyone considering this product it is very difficult to use. There are stains surrounding the sink area from the water that gathers while washing dishes. It scratches very easy and various foods and products leave blackish gray stains on it that will not polish out. I am very disappointed as the countertops look like I haven't wiped them. Yes, they are "old world" which is what I wanted but the look of not clean doesn't go well with a kitchen. The expense prohibits me from changing them too soon but I will in another 12 months or so. SANDY SMITH
October 22, 2007 Metal Tech USA in Peachtree City, GA stocks zinc coil and sheets. Blaine Gardner
November 7, 2007 I recently installed a zinc countertop in my home for my kitchen. I am very pleased with how it turned out. We had a local sheet metal shop do the bend for the corner and soldered the seams. I found this company Rotometals in California. They were very helpful with my questions and purchasing the zinc from.They are the only ones I found that you can order right on website. I had the metal ship directly to my sheet metal guy. I strongly recommend them for a source to get zinc sheets and the best prices even with shipping them to the east coast. Dana Potter
April 28, 2008 Zinc counter edging? Am so excited I found this website. My question is does any one know where I can get decorated edging for a zinc topped kitchen island? Kelly Rivelo
I'm looking for someone who can build a zinc table top, and ideally, also a base of some other material. Carole G.
I am a do-it-yourself homeowner interested in a zinc countertop.
Your site has some really good information on this topic. There is a
local roofing company who has zinc sheets (28"x120")for a very
reasonable price. They are .020 thick. I am covering my existing
laminated countertop with zinc. Will this thickness be ample? I am
not doing any welding (as I don't know how)! Jennifer Smith
I just had Zinc countertops installed today and they are
wonderful. I purchased the zinc a few years ago with this in mind and
found a sheet metal company that makes stainless countertops to fit
them for me. I bought the sheets at Home Depot that look like pressed
ceiling tins to use for the backsplash. Andi Kunert
December 6, 2008 This is for Andi in Des Moines. I went on the may house tour in Dubuque, Iowa a couple of years ago and one of the houses was a mine foreman's house with addition. fantastic job in keeping to the spirit of the original. used concrete countertops etc. but the master shower was concrete bottom sloped to the drain, no lip that way, and was made out of corrugated metal on the top and sides above a 2 or 3 inch lip around the other 3 sides. it fit into a sloped ceiling and looked fantastic. the architect did the labor as he was just out of school and friends with the owners. HE SAID THAT he used a couple of coats of a really good auto wax about twice a year to keep the shower from rusting and with the wax being a really good brand that you just sprayed it down with the shower head after using it. no chemicals to cut the wax finish. it had been in for a couple of years and hadn't started rusting as yet with 2 people using it every day. hope this helps you. Lois Gross
Save
