Copper plating steel grounding (earthing) rods
Finishing.com is made possible by ...
Q. Hi. I was going through the posts for copper plating of earth rods; even I am a manufacturer of earthing rods, we all face the same issues for copper peeling off from the threads and plating not even.
As for the threading we are able to thread on copper without peeling at the ends.
My question is related to uneven deposition of copper in the length of 8 ft.
If we are plating the rods horizontally in the tanks and I am rotating it at a constant speed then the deposition of copper is even in a range 4 to 7 microns -- but when you see it in the length it varies from 50 to 80 microns.
We are suppling current from one end right now. So the end on which the current is applied, the deposition is higher compared to the other end.
I need to reduce the variation to 20 microns.
And when we are rotating the rod, what speed is sufficient in your experience?
Ashwin Lohiya
Director - Mumbai, Maharashtra
May 26, 2023
Ed. note: Since you have solved the threading problem, which remains an open question here, please give the other readers of this mutual help forum some hints to its solution while you await someone to help you. Thanks.
A. Hello Ashwin,
It would definitely help if you could add another cable/connection to the other side of both anode and cathode bars. Your current density is higher on the ends, so bringing in your anodes from the ends will also benefit you. Lowering your amperage while increasing time will also help with copper thickness distribution. Hope this helps.
Mark L Baker
- Cazenovia, New York USA
June 4, 2023
thumbs up sign Thanks Mark for the reply; will try it and update.
Ashwin Lohiya
June 5, 2023
Q. Dear Sir,
We are exploring the possibility of a plant to do copper coating on a mild steel rod. Copper thickness required shall be in range of 20 micron to 125 micron.
Interested to receive electroplating process and how to do equipment sizing.
Rajan [last name deleted for privacy by Editor]
electric equipment supplier - Dubai , United Arab Emirates
A. Hi Rajan.
You might consider hiring a plating consultant, as it could take a long time from your starting point via this forum :-)
... but you need to start with the size and quantity of rods you want to plate. Then you decide how to handle them (general purpose racking either vertically or horizontally, vs. rolling them like in a conduit plater, vs. continuously end-to-end, etc). Then you need to pick a copper plating process; most likely you will need to cyanide copper plate them or nickel strike them as a first step before acid copper plating, and ending with a tarnish preventer. Good luck!
A. Hello Mr Rajan,
Firstly you should mention the application of the components which your are going to do copper plating for e.g., its printing roller, or earthing rods? Do you need a hard copper? Such details we need to suggest the right process and equipment.
praveen kumar
Praveen Kumar
plating process supplier
Mumbai, India
Q. I need to copper coat an earth rod (copper bond ground rod). As you may know, to comply with standards the thickness of the coat should be between 0.2-0.3 mm. Does anyone know the cheap easy way for applying this coating?
Is it possible to reach this thickness with electroplating or electroforming? Which one is best suited for this application (quality and financial wise)? Is there any other solution besides these two methods?
Arash Panah
earthing system - UAE
A. Actually, Arash, electroforming is the exact same process as electroplating. We just call it electroforming if the substrate is discarded or reused and serves only as a mold for the plating, such that the plating itself constitutes the whole finished object. In your case the steel rod remains in place underneath the copper plating, so it is not an electroforming operation.
Electroplating is how all your competitors make them. I can't say too much more about the exact methods because I was closely involved in the development of a process for one supplier and they used some non-obvious chemistry. But you might want to consider licensing the patented technology from Galvan Industries [Harrisburg, NC] because it is quite slick and very economical.
Q. I hope you do answer our question soon. I specifically write to you because I have seen you have a lot of knowledge about grounding rods. The problem we face is that after plating 250 to 300 microns of copper on the steel core we cannot do the threading on the ends of the rods as required. The copper leaves the rod. The bonding is good enough because we have carried out the bonding test. Maybe the copper is not ductile enough? How can the copper be made ductile easily. How are other manufacturers threading these ground rods after the copper plating?
Ajay Balaji
manufacturer - Mumbai, Maharahtra & India
April 13, 2008
A. Hi, Ajay. Unless you are doing an undercoat of nickel plating or cyanide copper, you probably do not have sufficient adhesion. If you are doing so, then the copper is probably too hard. Perhaps you can anneal it if you cannot deposit it in softer form.
A. If my conversion is correct, you are plating about 0.001 inches of copper.
When you thread an end, the copper is not going to stay attached to the core in the threaded area. If it is peeling off beyond the threaded area, then you do have a bond strength problem and your test is not adequate for the use.
One way would be to mask off the end, so you do not have to thread the copper. But why are you threading the rod?
One American chemical company sell proprietary solutions that are made for this purpose and it evidently works. I think that it is an electroless process, so maybe the rod is pre-threaded. Maybe you can overcut the thread by 0.002 per side and truncate the top of the thread more than normal and be able to plate the threads without having to "chase" them after plate.
Q. Dear sir
I want to start a earth rod manufacturing industry I am pretty confused about the copper coating process can you please tell me what kind of machine I require. Is it expensive?
Regards gladson
Gladson Anchan
- Bangalore, Karnataka, India
May 26, 2009
A. Hi, Gladson. If you have not yet visited a couple of ground rod or copper plating facilities and read up on it, I'm not sure that you are yet ready to choose which style of machine you need.
The rods can be hung from a rack vertically, or they can be hung from a rack horizontally, or they can be plated while rolling in a machine similar to a conduit plater, or they can be plated continuously, end-to-end. If you have a lot of patience you can probably see sketches of these various approaches in patents. Good luck!
Q. When I copper plated the rods of size 2500- 4500 mm, the deposition of copper is less at the center of the rods...
Can you suggest some remedies for this.. for 250 microns rods.. and as per UL (Underwriters Laboratories Inc.) standard
Abhiraj Naik
engineer - Mumbai, Maharahstra, India
September 15, 2011
A. Hi, Abhiraj
If you are plating these vertically in a conventional tank, the most obvious improvement is to shorten the anodes. This increases the distance from the anodes to the top and bottom of the rods, thereby reducing the buildup on the ends. Please start by telling us what you are currently doing. Thanks!
Q. Hi Sir,
Our tanks are horizontally placed and the rods are placed in the tank parallel to the ground level.
Can you suggest some remedies for this or 250 microns rods.. and as per UL (Underwriters Laboratories Inc.) standard.
The time limit is 215 minutes.
And still we don't find the perfect finish nor the deposition of copper is very satisfactory.
Please suggest some remedies in this.
Thanking You.
Abhiraj Naik [returning]
Engineer - Mumbai, Maharahstra, India
A. Hi, Abhiraj
The plating is thinner near the center and heavier at the ends because there is more electricity flowing at the ends because of the way the electricity bunches up on the ends unless the span of anodes on the anode bar is shorter than the grounding rods.
35151
The easiest fix is to remove the anodes near the end, making sure their span is significantly shorter than the length of the grounding rod. If this isn't enough, you can install "shields" -- vertical PVC or polypropylene sheets that block the shortest current path to the ends of the grounding rods. If the path is longer the resistance will be higher and the excess plating thickness eliminated.
But if you are having multiple problems like "very unsatisfactory deposition", you might wish to retain a finishing consultant; trying to learn satisfactory plating from trial-and-error and books can be a big challenge. Good luck.
Q. The answer you gave me was not satisfactory.
Please suggest some other remedies for this as we copper plate rods of various lengths from 4 feet to 10 feet.
October 5, 2011
A. Faraday's Law tells us that the thickness of metal deposited will be proportional to the current flowing to it. That is, the plating thickness will follow the current distribution. I suppose you could alternately bend the anode rods into a dog-bone shape so that the anodes are closer to the rod you are plating at the center than at the ends; or put plastic shields at the ends of the rods. But if you do not refine the primary current distribution through either the arrangement of anodes or the installation of plastic shields to divert the current, unfortunately you will not ever be able to solve the problem of uneven thickness.
As for whatever other plating problems you are having, if you describe what you are doing in terms of process: sequence, concentrations, temperatures, etc., and in exactly what way the plating is unsatisfactory, people may be able to help you. Best of luck.
Q. We are in search of an electroplating plant where we can produce 100 to 300 micron copper coated MS rod 12-20 mm OD, 10-12 ft.long. We want to rotate the MS Rod at the time of electroplating to get uniform copper coating 100-300 micron. Is it possible?
Amit Sarkar
- Kolkata, West Bengal, India
January 3, 2013
A. Hi Amit.
Try reaching out to Laurens Willard of Galvan Industries, Harrisburg, No. Carolina to see if they are interested in licensing their process and machine design. They copper plate grounding rods. Although there are many companies who can build a plant for you, knowing from experience what works and what doesn't is always a great start, and Galvan invented, developed, and patented a really impressive total process and equipment solution :-)
I did some consulting work for them years ago, but I learned from them far more than I taught them, so I cannot reveal the things they taught me ... and I'm not sure I can be of much help to people on ground rod plating while hiding what I learned :-)
Luck and Regards,
Q. My name is anandh kumar from Chennai
I am doing acid copper plating; I am doing earth rods. For plating these rods we want 250 micron but I need even microns in the rod .
Anandh kumar
- Chennai Tamil Nadu, India.
July 17, 2017
A. Hi Anandh. We attached your inquiry to a discussion on that subject. If it does not answer your questions, please tell us what you have been doing and what is happening. Thanks.
pic of Ted Mooney
Copper Plating on Mild steel rod
Q. Dear Sir,
When threading is done on copper plated steel rod. Copper tends to peel off on threaded part . Coating thickness is more than 250 micron. Can you suggest any suitable measures to solve this issue??
I have tried various pre treatment process like acid and electro cleaning, but none of them worked yet.
Also tried copper strike using cyanide ...
24506-1cyanide   24506-1cyanideCloseup
as well as nickel bath prior acid copper plating...
24506-1nickel   24506-1nickelCloseup
Still there is no improvement.
Kindly suggest.
Rahul Maurya
- Mumbai, Maharashtra, India
October 27, 2017
A. Hi Rahul. Only if you are roll forming the threads is there any possibility at all. For the benefit of other readers, if you are cutting threads into the rod after the copper plating, there certainly would be no copper plating on the underlying steel, no matter what technology was used in applying it.
Your questions are always welcome in this forum, but your e-mail address has been used by your predecessor or a co-worker over a period of more than 6 years now, posting dozens of questions on virtually every aspect of ground rod plating technology -- from poor appearance, to bad adhesion, to uneven thickness, to the plating turning green, to questions about lacquering grounding rods, to threads being blocked by plating after threading -- during which time we've suggested that your company might want to try to license the technology, or to retain a consultant to guide you in the technology. I'm just concerned that without hands-on help you don't seem to be making much progress in this forum even over the course of many years :-(
But just to assure crystal clearness, you have personally verified that these threads are being rolled after plating? And the plating doesn't adhere at all regardless of whether you use a copper cyanide or a nickel strike, correct?
I don't know the normal approach in rolling the threads on plated grounding rods, but the general case for rolled threads is that the ends of the rod must be reduced to the mean diameter of the threads before rolling because otherwise there would be nowhere for the metal to flow. Are your ends reduced before plating? From these photos, it doesn't look like it, and I wonder if the case is that the dies thus allow no room for the plating so they must tear it off. What is the thread specification and what is the diameter of the rod ends before rolling the threads? Does the rod end diameter after plating match the mean diameter of the thread? Thanks!
pic of Ted Mooney
Q. Hello Ted,
I have got a similar problem as Rahul.
1. Unable to achieve threading after coating and 2. Uneven coating on the rods.
Our earth rods are horizontally placed in the tanks and are rolled physically by human by wearing gloves and putting his hands in the tank. So mostly the rolling of rods is not continuous and the rotations differ for each rod. I believe this is the reason for uneven coating. Because we have tried all other measures like shortening the distance between anodes.
Coming to the 1. Issue. The diameter of rods after coating is 17.2 mm and before coating is 16.7 mm. Mostly threading of 3/4" has to be done on it.
We are currently using roll press machine for threading.
If these two things can be solved. We will be able to satisfy our customers like you with the earthing products even better.
Can you help me with this sir?
TIRATH NAGDA
- Vadodara India
February 1, 2018
A. Hi Tirath. We've moved from copper plating, which I know at least something about, to standard blank dimensions for thread rolling, which I know nothing about :-)
But even still, how can you be putting a 3/4" thread on a rod of .677" (17.2 mm) diameter? My very limited understanding of thread rolling from a few minutes of Googling, says that the blank diameter for rolling a 3/4-10 thread must be 0.689" ± .001". But again, I have no experience with this and I do see other suppliers claiming that their rod diameter is 17.2 mm as well. Please download some general info about thread rolling, get with your machining department, and try to resolve a chart with all the proper chamfering, blank grinding, and thread rolling dimensions. You probably need to talk with the supplier of the thread rolling machine for a deeper understanding -- perhaps special blank diameters are required for composite materials like copper plated steel; or perhaps different material of construction is required for the rolling dies when rolling soft materials like copper; or different speeds & pressures.
Sorry, you are out of my field with this, and some suppliers (http://www.amiableimpex.com/ground-rod-catalog/threaded-copper-clad-rod/Threaded-copper-clad-earth-rod.pdf) claim to do the threading before plating :-(
Best of luck.
pic of Ted Mooney
Q. Hey Ted,
Thanks for investing your time in researching about the Roll threads and trying to help me with my question.
Mr. Ted, I have seen you posting several times about asking people to licensing the technology from Galvan Industries.
I would like to ask you if you know that Galvan Industries uses the same technique of threading on their plated products or not?
Also, I'm interested in hiring a consultant from the US to help me with this issue in my factory. Do you have anyone in mind who is willing to come to India and give consultancy in exchange of money?
Awaiting for your prompt response.
Tirath Nagda [returning]
- Vadodara, Gujarat, India
February 3, 2018
A. Hi again Tirath. Yes, I have suggested that people from other continents see whether Galvan is interested in licensing their technology there because when I saw it many years ago I was very impressed by the economy of their very innovative approach to plating grounding rods.
Sorry, I have no idea how they thread them; my visit was years ago and threading wasn't of interest to me, but I wouldn't be able to comment on the subject if I had seen what they do. I do see in their published data though that their 3/4-10 threads are on .673"-.683" diameter rods, so I guess 17.2 mm rod diameter sounds right after all :-)
I don't do consulting anymore, but hopefully someone else will respond.
pic of Ted Mooney
