![pub](/gifs/pub.png)
Air curtain causing damaged parts
Air curtain on the exit end of our paint curing oven is damaging parts due to the air curtain causing the parts to swing wildly and creating damaged parts
Tim Barbour- Hamilton, North Carolina
Tim,
The reason for your parts swinging wildly, as you put it, is due, I guess, to an excessive air speed.
You have a few options.
l. Reduce the air speed
2. Increase the gap between the parts and the air curtain, i.e., make the gap much wider = less disturbing air velocity
3. Rigidly mount the parts so that they don't swing about.
![freeman newton portrait](../portraits/freeman_newton.jpg)
Freeman Newton [deceased]
