Aqua Regia Gold and Aluminum
Will aluminum in an aqua regia solution with gold cause problem precipitating gold from solution? I'm trying to strip gold from Computer CPU's. 2 of the cpus have small aluminum heat syncs. There are about 20 cpus total.
Chad Arlt
- Alpena, Michigan, US
I would suggest filtering your solution before precipitating the gold, other than that it shouldn't be a problem. You could always dissolve the aluminum in sodium hydroxide first if desired.
Good Luck,
Jim Sivertsen
- Alden, New York, U.S.A.
