Letter 22035
Need a replacement process for etching
aluminum
We have an aluminum etching process where our operators mix
Hydrochloric acid (37%) and cabosil to form a paste. The paste is
then brushed over the surface of the aluminum. The paste stays in
contact with the aluminum for 8 minutes and then is rinsed off with
water. The process is performed in a booth and the operators are
required to wear full face air supplied respirators and acid suits.
Is there a safer alternative for etching aluminum, that will give a
similar degree of etching? Another chemical we can use rather than
HCl? Our pieces we work on vary in size from small brackets to large
(up to 16') panels of aluminum.
Thanks in advance for your assistance.
Todd Wegenast
- Melbourne, Florida, USA
Most shops would use an immersion in a caustic tank rather than an
acid etching slurry. I don't, however, know if it is practical to dip
your parts, and you may have to de-smut them after etching.
finishing.com
Brick, New Jersey
We are trying to find an alternative to etching this way as well.
The finish we are getting is too dull. In order to get a shiny finish
we have had to switch to stainless steel. Is there any way to get an
etched look without the white chalky residue?
Laura Burkholder
Nameplate and domed labels - Arlington Hts, IL, USA
Caustic soda (sodium hydroxide) is commonly used in the industry
for etching aluminum. As indicated by Mr Ted Mooney, the parts will
have to be desmutted/deoxidized. Dependent upon the concentration,
temperature, bath age, and metal loading, the etch rate of caustic on
aluminum will be affected, but it is normally quite slow and the
depth of etch is fairly shallow. The end use, or post process, i.e.
chromate conversion, bonding, paint, will determine the type of
topography you will need to create on the part/s. Alternate acidic
etchants based on ferric or cupric chloride can be used. In the
chemical machining industry the etchant most widely used is ferric
chloride. The same basic parameters of concentration, temperature,
metal loading, etc. will also influence etch rate. Please note
however, that the etch rate of ferric versus caustic is many times
higher and tests to determine the etch rate for a specific set of
parameters should be determined. As with caustic, ferric etching will
cause a smut to form on the parts which will have to be removed. A
very effective desmut and bright dip solution can be made as follows:
D.I. water - 95% b.v.
Concentrated nitric acid - 2.5% b.v.
Concentrated hydrochloric acid - 1.5% b.v.
Concentrated Hydrofluoric acid - 1.0% b.v.
Temperature - ambient
Dwell time - ~ 1 minute
Please note!!! Please read MSDS's for all acids, paying careful
attention to handling, protective gear, storage, and disposal
instructions. These acids are nasty but very effective at performing
the desmutting and bright dip step of the process.
Ferric chloride is very effective on stainless steel as well. It
will require a higher concentration and longer dwell time. The smut
that is formed is very tenacious but can be readily removed using a
modified version of the acid desmut cemistry as described above. A 1%
- 2% addition of hydrogen peroxide needs to be made to the acids.
Compensate for this addition by reducing the water concentration
accordingly.
Wade Rohland
Techni-Trax - Ramona, CA, USA
May 14, 2006
Just a word of caution, Hydrofluoric acid (HF) is very dangerous.
It is unlike other acids, in that, after exposure, not only is the
immediate first aide important but also monitoring of Calcium levels
in the blood. Fluoride ions penetrate through the skin and bind up
calcium forming an insoluble salt. An exposure of a 50% soln over an
8" x 8" area can be deadly! Keep Calcium Gluconate on hand and by all
means read the MSDS!
James Brock
- Newport New, VA, USA
May 15, 2006
Thanks for the very important note, James. The dangers of HF are
in a whole different category than most other acids.
 Ted Mooney, P.E. finishing.com Brick, New Jersey
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
