- Pine Beach, NJ
for Metal Finishing since 1989
Galvanic action between carbon and stainless steel
I would like to know about the expected galvanic action between stainless steel (304)and carbon steel in a corrosive environment, within a few hundred yards from the coast. The application would be stainless steel bolts and screws to galvanized carbon steel. What would you suggest to use as a fastener if stainless were not acceptable? Cadmium coated bolts with dielectric washers has been suggested however I think that it would be overkill. Bolt manufacturers are saying that cadmium coating is becoming obsolete.
Kenneth PaquetteBRPH - Cocoa Beach, Florida, USA
Galvanized hardware would be best. Cadmium is not actually becoming obsolete, it's becoming used only on applications that really need it, and it would offer nothing special in this application if galvanized hardware can be used instead.
