Carbon Fiber Corrosion on Metal?
I am into the current craze with carbon fiber paneling. I work on aircraft and deal with structural maintenance and corrosion. I remember learning about graphite paneling and it's severe corrosion potential on unprotected metal. I am looking to cover steel car paneling and Al auto parts with a kevlar/graphite weave for cosmetic appearance. I wonder what kind of problems are foreseen? I intend to sand and clean the panel with 180 grit and final clean with alcohol. After this lay the fabric with 3M spray adhesive [adv: adhesive spray on eBay or Amazon (adv.)] and epoxy/ clear coat over the top. I wonder if the 3M adhesive is enough of a separation to prevent corrosion on metal parts or if something else is needed.
Thanks for your help,
Alexander Duncan
USAF - Dover, Delaware, USA
As long as there is no liquid or gaseous via for the metal ions to travel, there should be no or almost no galvanic action. If the procedure intrinsically involves some kind of liquid but eventually freezes (crosslinking) then the possible attack will stop soon and you can rely on the composite.
Guillermo Marrufo
Monterrey, NL, Mexico
Hi Alex,
I think that Guillermo's reply hits the nail on the head.
The only time you'd encounter 'problems' with metallics and composites would be a) longish term b) constant travel of acid fumes.
The reason for this is that the permeation of glass fibre epoxy or thermoset composites, silicon carbon fibres is more pronounced than with thermoplastics. I can only recall one instance (Stelco Steel, Hamilton, Ontario) where the embedded metal reinforcing failed due to permeation in an exhaust system.
Worry not. Thy panelling will not be affected.
freeman newton portrait
Freeman Newton [deceased]
