Copper plate with a steel backing
We are looking for a copper plate with a very thin steel backing. Simple enough except they can't be held by an adhesive. The copper portion of the plates will be chemically milled for use in the hot stamping of foil in a printing operation. The steel backing allows the mounting of the plates on magnetic printing cylinders and magnetic flat bases. I've heard of chemically bonding copper on steel and "growing" copper on steel, but know nothing about the process. The problem with adhesives is the plates will be heated to 400 degrees F for a few hours, then cooled, and then reheated again for a few hours, then cooled, and so on. If anyone can help, I would greatly appreciate it. Here are the specs: Copper plate approximately .0600" (1.5mm) thick with a .003" (.07mm) steel integrated backing. I need(Costs, Minimum Order, etc.) on this product. A similar plate in Brass may also work.
Michael Wilks
- Newton, Kansas
Hi, we are looking for the same thing but in Brass and the thickness needs to be 0.6mm ( Brass ) on 0.4mm Steel Backing.
Let me know.
Marius Carstens
- Cape Town, Westen Cape, South Africa
