Cold blue removal
I purchased an antique Colt SAA which has been cold blued. I would prefer to have it in the state it was before cold bluing. Is there any way I can remove the cold blue without removing any original finish or patina that might remain?
Bruce Bogart
- Redondo Beach, California, USA
I'm not an antique firearms expert, but bluing solutions react with the raw metal, not patinas or finishes. So if you remove the bluing I believe you will be left with raw steel.
Bruce, any of the bluing removers I have used will take off all bluing and leave bare metal. You are probably best off just leaving it alone, or find a good gunsmith who can reblue to the original finish.
Good luck,
Ed Kay
- St.Louis, Missouri
