MEK rub test for paint
⇦ (tip: readers usually show little interest in abstract questions,
but your actual situation will usually bring responses)
Q. How many micron thickness reduction after rub test on painted panel?
Mahesh yadavEmployee - Mumbai, India
October 25, 2023
for Shops & Engineers
Q. I am involved in aluminium coating industry, I heard MEK / methyl ethyl ketone rub test from several paint supplier, they feel that this is the basic test for paint finishing quality test. But I feel that this is not true, why I conclude this because the pressure on the cloth to the panel is not control if do the test manually. Second, different property of paint and powder will have different reaction to the MEK. I do even heard that some of them said without any removing of paint will consider pass, but some of the standard stated that no no substrate show through will pass the test, no idea which one is correct. Any opinion on this issue?
Hanson- Singapore
A. Please use the search engine. This had a fair response to a similar question a year or so ago.
James Watts- Navarre, Florida
A. Dear Hanson,
This MEK test is just for zinc-rich primers. You can refer to ASTM D4814 for further information. In this standard the degrees of removing the paint are defined.
- Turkey
Q. May I get MEK test acceptance detail. Thanks
Rizwan- Pakistan
May 22, 2011
Q. Even if we have ratings from ASTM D4814, which is the rating that is acceptable in the case of Inorganic zinc silicate primer?
Please advise.
- UAE
May 1, 2012
About/Contact - Privacy Policy - ©1995-2024 finishing.com, Pine Beach, New Jersey, USA - about "affil links"
