Transparent Conductive Coating
I am looking for a technique to apply a transparent conductive coating on a ZnS coated copper wire (~1mm dia).
Sputtering will do but it is very expensive and is not convenient for such a geometry.
Spraying, dip coating or sol gel technique would be a feasible solution. But how?
Welcome any suggestion.
Hong Kong Productivity Council - Hong Kong
You need something like a spray-on Tin Oxide coating. This coating is commonly used in the solar-cell applications and is available commercially. Talk to some of the solar-cell folks or find some of their literature. I am sure there are many patents on it.
Mandar Sunthankar- Fort Collins, Colorado
Bayer sells Baytron P a conductive polymer suspension in water that might solve your problem
Jaap FolmerNCSU - Raleigh NC USA
1.why need transparent Conductive coating?
2. why do you apply Conductive Coating colored Copper-like?
3. What does coating work for? For protection? or other Proposals? Ed
Hansen Hi-tech - zhejiang,China
I want some information about physical character of solar selective coating for thermal tecnonogy
Pham Duc ThuanHai Phong University - Hai Phong, Vietnam
transparent conductive paints are available from many sources now a days. A good product is marketed by agfa - various grades of
"ORGACON" - you can select depending on your need. Bayer is marketing Baytron F CPP 105 DM. You can also try CNT based "transparent ink" made by Eikos in Franklin MA.
If you can manage with non transparent conductive coating, there are many more suppliers who make silver/gold/graphite based formulations.
- Calcutta, WB, India
