Material specs for hard alumite
I am a post graduate research student in the field of robot structures. I am unable to find the elastic modulus for hard alumite used in pneumatic actuators. Seeing your discussion has helped me understand to an extent what it is but could you also help me with the material spec for it.
Thanks in advance,
Chandra Murugayah
- Perth, Western Australia
One abstract thrown up by a quick web search reads:
TiO2 was deposited onto hard alumite (Al/Al2O3/TiO2) by alternating current electrolysis and precipitation in (NH4)2[TiO(C2O4)2] solution at various temperatures, where the hard alumite was prepared by the anodic oxidation of aluminum in sulfuric acid (Al/Al2O3). The TiO2 electrodeposition mainly occurred at temperatures lower than about 50 °C, while the TiO2 deposition due to TiO(C2O4)22&#8722 absorption onto alumina predominantly occurred at temperatures higher than about 50 °C. The amount of deposited TiO2 increased with the increase in the deposition temperature, leading to high photocatalytic activity. The deposited TiO2 at 90 °C followed by heat-treatment at 550 °C had an anatase structure and showed a high photocatalytic activity for the decomposition of acetaldehyde even under fluorescent lamp illumination. The Al/Al2O3/TiO2 prepared at 50 °C was optimal for practical use, because of a relatively high activity and the sufficient adhesion strength between the TiO2 and the Al/Al2O3 substrate due to the presence of the deposited TiO2 in the pores of the alumina film.
May be of some use to you? - maybe not the TiO2 part, but hard alumite is described.
Bill Reynolds
Bill Reynolds [deceased]
