Electrolytic rust cleaning
I want to use a low tech electrolytic process to remove rust and stains from hand planes - usually made of grey cast iron with blades of steel.
John Wilson
- Riverside, California
A tablespoonful of washing soda [on eBay or Amazon (adv.)] , (not caustic soda - which I think you might know as Lye?), in a gallon of water. A lump of iron or stainless steel (stainless won't erode) as the anode (positive) and the article to be cleaned as the cathode (negative). Connect to a battery charger [on eBay or Amazon (adv.)] (12 volt) and leave for an hour or two. The rust will become blackened. Rinse it off under a tap - use a Scotchbrite scouring pad if you like. Nothing will be removed but the rust. Any bright steel will remain bright. Widely used for cleaning old hand tools - try it on a rusty spanner (wrench) of something first - you'll be amazed. Remove wooden handles if you can - otherwise don't leave them submersed too long.
Dave Fisher
- Northants, England
The use of stainless steel for the donor is dangerous and NOT recommended as there are highly toxic byproducts produced if it is used.
Fin Fagin
- Vlahalla, Georgia, USA
Hi, Fin. Please expound, I've never heard anything like that. Thanks.
