Degreasing
We are drawing aluminium wire. We need oil free surface finish on the drawn wire. Could someone recommend a degreasing agent / process or any other alternative.
Ashwin Bhatia
- NOIDA, India
Try to raw wire with "soap" instead of oil comes off with hot water.
Chris Snyder
plater - Charlotte, North Carolina
It would be better if you use Aluminium Degreaser that would remove oil and oxide scale and brighten Aluminium wire also. There are different products also available.
Vinay Golwala
- Mumbai, India
I need a chemical that can do the same thing to stainless steel.I am looking for cleaning,degreasing and mainly brightening effect for wire mesh.
Pl.suggest
Pankaj Bawiskar
- Mumbai, India
