Zinc sulphate treatment of cast ductile iron
I am seeking a method to protect cast Ductile Iron parts for use in high temperature, high humidity environment, close to the ocean. 316 Stainless is usually specified but I have been told that a treatment with zinc sulphate may be superior to even 316. How could this be so? The items are cast into the outside of concrete walls.
Ernest Comerford
- Brisbane, Queensland, Australia
This sounded intriguing, but in searching the Internet and reference books back to the early 1960's, I was unable to find such a treatment. Perhaps someone was thinking of a zinc chromate-containing primer?
If the parts are already installed, and assuming high temperature refers to ambient conditions, I recommend a good cleaning (using a phosphoric acid rust remover if necessary), followed by a zinc-rich epoxy primer and a polyurethane topcoat.
Ken Vlach [deceased]
- Goleta, California
