Ebonol C blackening problems
Q. I want to change some brass candlestick holders from brass to black without ruining them.
Gill Manning- Hertfordshire, England
A. There are two basic options. Both involve making sure the brass is very clean before you start or you will have problems with adhesion and good film thickness. I suggest you give the brass a very good clean in both acid and alkaline cleaners; the exact process will depend on what you have available. You can then paint the brass with a suitable paint; probably acrylic is the best option, although if you have access to electrophoretic paint, this is better as it will get into all nooks and crannies and will give a more consistent coating.
Secondly you can dip the brass into a sulfur solution. This is usually made by dissolving flowers of sulfur in a solution of sodium sulfide. The solution will go a sort of yellow colour and will stink, but it is very good at blackening metals. However, its success may be dependent on the type of brass you are using as different brasses have different amounts of zinc in them.
To get best consistency, try carefully etching out the brass from the surface, but be careful, as removing too much zinc will result in "dezincification" which will leave a copper sponge with no structural strength.
Our company manufactures promotional and recognition award jewelry. We have been using a product called Ebonol C in a bath solution for blackening brass (85/15, copper/alloy) emblematic jewelry (tie tack and lapel pins mostly).
The parts are blackened and then buffed on an semi aggressive lea wheel to achieve an antique finish look. The parts look great at this point. We then mask off certain areas with ochre and buff them again with high gloss polish wheels. We then wash off the ochre and polishing compound in an aqueous degreaser and ultra sonic. This process has served us well until lately. Now the black ox is falling out in during the washing process no matter how carefully guarded. Is there a trick to washing parts that have been oxidized with Ebonol C? Or is there another blackening agent that might be better suited to our needs?
Any input would be greatly appreciated.
Sincerely,
Roland Dion- Attleboro, Massachusetts
A. Ebonol C is the world's standard for applying black oxide coatings on copper and its alloys such as brass. Nearly everyone in the finishing world has done it at one point in their career. There hasn't been any change in the formulation of the material, to my knowledge and on going experience, and while the manufacturer's name has undergone change after change due to acquisition, it's the same old Ebonol C.
Couple of thoughts: if the Ebonol hasn't changed and your process for applying it hasn't changed, look at what happens ahead of Ebonol application. Specifically, what buffing compound changes have been made. Also, what about your brass - has the lead content or other alloying elements changed? In order to get the best black on brass, sometimes need special "Brass Activator."
As one who owns a shop that has done Ebonol C for nearly 40 years and still gets out and dips his hands in the "vats", better look elsewhere. Our Ebonol is still working fine.
Milt Stevenson, Jr.
Syracuse, New York
A. Check your acid activator.
Russell Richter- Danbury, Connecticut, USA
A. I use a chlorine solution to blacken sterling silver and I also use iodine [affil links], like you buy for cuts, to blacken gold. Try one of those to blacken the brass.
John Legere- Lake Worth, Florida
Blackening Brass as Black as Possible
August 20, 2015Q. Hi All,
Looking for the most effective way to give a brass component blackest finish possible.
I have the following reference I'm trying to match. My component is very similar, a brass machined rod 63.5 mm x 225 mm.
I know this about the above: "Each object is hand made under the supervision of Carl Aubock IV at the Carl Aubock workshop in Vienna, founded in 1900"
All/any expertise very much appreciated.
Cheers,
Designer - London, UK
August 2015
A. Hi Hayden. Selenium dioxide is what trophy suppliers use to get the dark black lettering on trophies. Ebonol C is the best known commercial blackening process for brass.
Sorry, we can't print any comments about what Carl Aubock IV specifically might or might not do -- that would be a bit too close to crowd-sourcing industrial espionage :-)
A. What Ted refers to is also the chemical bath that faucet companies use to create an oil rubbed bronze patina on brass. It results in a black finish if you don't do it right. I know this for a fact since we just went through the process of matching an oil rubbed bronze patina with a slightly brown tinge. The bath is an acidic solution containing selenium, and is commercially available.
PVD Consultant & Wine Lover - San Diego,
California
August 31, 2015
A. There's another, completely different brass blackening process. I do not have the formula in front of me, but you'll find it in the OLD "Metal Finishing Guidebook". copper carbonate is dissolved in full strength aqua ammonia, and the parts immersed in it at room temperature. A shop I used to work for used this method on some brass cylinders they got once in awhile and it seemed to work fine.
Dave Wichern
September 22, 2015
Readers may also be interested in these threads:
Letter 32355, "Black Oxide on Brass / Black Anodizing of Brass"
Letter 1198, "How to Darken Copper, Brass or Bronze".
