Temperature effects on the oxidation of metals
We are doing a project to show the affect of temperature on the oxidation rate of different metals. Do you have any suggestions on what metals to use, so that we can measure an appreciable oxidation in a relatively short period of time?
Stephen Arnold
- Allentown, Pennsylvania, USA
Most metals will oxidize quickly. Aluminum, lead, steel are three readily available ones. Cut a section of the metal, or sand the surface with sandpaper and you should see changes very quickly.
Iron would produce a good rate of oxidation. also blue steel (steel that has yet to pickled).
Heather Essary
- Woodhaven, Michigan, USA
Stephen, did you find any information about temperature effects on rate of oxidation? I need the same information but could find any.
Kha Le
- Foothill Ranch, California
I have been trying to find the material of thermal rate of oxidation. Stephen if you have found any, could you pass on the reference.
Nageswararao
research - Lincoln, NE
