Cleaning a Galvanized Duct
I want to clean and coat a galvanized duct at the plant. What type of coating, besides painting, could be applied?
Jossimar Diaz
- Ciales, PR
To clean the duct you should follow the NADCA Standard ACR 2002. There are different products you can use inside the ductwork, if the ductwork is crawlable you may use a paint_sprayer_airless if not you can use a robotic car to introduce the application tip inside the ductwork.
Carlos Gonzalez
- San Juan, Puerto Rico
