Variation in thickness of nickel plating
Q. In a large scale automatic installation for multi-layered nickel plating on MS substrate, wide and wild variation in thickness of nickel deposit is encountered. thickness varies from 8-40 microns for average thickness of 20 microns. There is a variation from component to component & also on component itself. the variation is also noticed on a surface which is almost parallel to anode surface. Kindly throw some light as to which factors besides jigging, can have this influence on thickness distribution. can chemistry of the bath/additives play any significant role in this case? Thickness is measured by magnetic gauge.
Thanking you,
D.T.Thakur
- Mumbai, Maharashtra, India
A. Hi. D.T. I've never heard of additives wrecking the thickness distribution, but you should plate a panel in a Hull Cell and test the thickness distribution to see what you find. Good luck.
A. D.T.Thakur.
There are several reasons for non uniform nickel deposit.
1) Check distance between anode and cathode, need certain distance.
2) Rack design is very important for uniform deposit.
3) You have to analysis your nickel bath chemistry.
4) Check enough nickel in your nickel baskets.
5) Uneven air agitation in nickel bath.
popat patel
Popatbhai B. Patel
A. Factors that can affect the thickness distribution are numerous. You correctly identify jigging, but there is also tank loading, bath pH, current density, screening, shielding etc. If the tank is overloaded you will have parts screening other parts, so you will get poor reproducibility. If the bath is too low pH, then you encourage hydrogen evolution and this can selectively replace metal deposition. If the parts are not jigged correctly, you will get preferential current passage. If multiple jigs are used, the resistance of each path will affect the current and hence the thickness. As Ted says, do a Hull Cell and see what that tells you about he chemistry of your system. If that is OK it must be the electrics and/or the tank geometries
Q. While electroplating a case of a watch with Ni the top surface gets a coating of 9 microns where as bottom gets 7 microns it is in a jig which is rotating on itself and also the case.
Ajay Prasad
Student - Chennai,Tamil Nadu, India
June 27, 2017
Ed. note: For a deeper and more theoretical discussion, please see letter 3795 "How to overcome non uniform thickness of coating in electroplating"
Nickel distribution
I'm searching for a good description regarding nickel distribution, a Photoshop or a chart.
Anders Sundman
Anders Sundman
Consultant - Arvika,
Sweden
October 26, 2017
A. Hi Anders,
You may refer below Nickel Plating Handbook and Thickness Distribution Control of Electrodeposited Nickel journal link, if able, to get your required info.
https://www.nickelinstitute.org/~/media/Files/TechnicalLiterature/NPH_141015.ashx
http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.405.6287&rep=rep1&type=pdf
David
David Shiu
David Shiu
Great references, David! Thanks!
pic of Ted Mooney
November 2017
Q. I am facing a problem in nickel sulfamate solution. High nickel deposit at the end where I used masking. I know at the start and at the end position current flow that area convert it to HCD area. Give me solution for resolving this issue.
Sanjeev Sharma
- Baddi himachal
November 28, 2020
A. Hi Sanjeev. Yes, if you mask an area, the current that would have gone to that masked area is diverted to the next closest spot, which can result in heavier plating along the masking line. But it's hard to propose an exacting fix to a vague general problem :-(
If you can remove or mask the anodes in that area, or insert non-conductive plastic shields you can minimize the problem. But send photos or a sketch of the anode-cathode-masking situation to mooney@finishing.com for posting here..
pic of Ted Mooney
November 2020
