Help with custom car alloy top finish
Custom aluminum car top finish- the four sections of the top has been heliarc welded together. Interested in a protective process to keep the finish aluminum? any suggestions would be appreciated.
Jeff Gamble
- Tucson, Arizona
I think your two choices are anodizing and a clear coat lacquer.
Ted thanks for your reply however while I like the anodized finish I understand anodizing will make the weld lines more pronounced.
Jeff Gamble
- Tucson, Arizona
Yes, unfortunately it probably will.
