Help on Teflon coating
I would like to know the details about coating Teflon on kitchen wares and cookery pots. Is liquid Teflon available in India?....what are the machinery equipments needed for Teflon coating?
Sudharshan
- Palakkad, Kerala, India
First of two simultaneous responses -- 2002
Teflon coating is available as a liquid paint. Application by spraying or dipping. Curing approx. 30 mins at 350 degr C.
Good luck,
Remmelt Bosklopper
Remmelt Bosklopper
- Enschede, The Netherlands
For availability look for Dupont or Whitford representation. Application is handle in various forms from chain-on-edge machines to full overhead conveyor systems. Will normally require heat curing. Material applied using HVLP, Conventional, Air-Assisted Airless and Electrostatic.
Hope this helps,
Gordon Vidt
- Newark, Ohio
Dear Sir,
Yes! all this technology is available in India locally. You can contact to any one, you will get a information properly.
Wish you all the best,
kalyan dhakane
Kalyan Dhakane
Mumbai, India
