Sodium Hypophosphite to HYPOPHOSPHOROUS ACID
How do you get HYPOPHOSPHOROUS ACID from Sodium Hypophosphite. Do you just add muriatic acid (37% Solution) to Sodium Hyphosphite (powder) ratio of 50/50. Then distill it. If this is correct which is the acid? The mixture that was boiled or what was condensed into the other container.
Mark T [last name deleted for privacy by Editor]
- Asheboro, North Carolina, USA
