Simple test for presence of clear chromate
(to hopefully help readers more easily follow the Q&A's)
Aluminum is often 'chromate conversion coated' either as a corrosion resistant final finish or as a pretreatment for painting or powder coating. As with most metal finishing, the process actually involves many steps, usually including alkaline cleaning, etching, deox/desmut, the chromate conversion step per se, and water rinses between each step.
MIL-C-5541 / MIL PRF-5541 / MIL-DTL-5541 [on DLA] is the most commonly cited specification for the process.
Alodine & Iridite are trade names of major suppliers of the process, so people sometimes refer to it as "Alodining" or "Iriditing". "Chem film" is another term for the process, used mostly in the USA.
Q. Are there any test kits available to test that your aluminum components have been coated with Military specification MIL-DTL-5541 (Chemical Conversion Coatings on Aluminum and Aluminum Alloys) applies to chemical conversion coatings.
Any help will be appreciated.
- Baltimore Maryland
July 27, 2022
A. Hi David
I feel your pain. i have a few suggestions to offer you. The first is try painting a panel. Yhe yellow chem film is used for paint adhesion in lieu of primer. I don't think there is anything magical about the yellow as opposed to the clear (although I could be mistaken) so a simple adhesion test might do the trick to prove application.
The second is a little more involved. back in my machine shop days (35+ years ago) there was an inspection machine known as an optical comparator....an amazing piece of equipment. it was capable of measuring extremely small dimensions and if not mistaken it may have broken them down into the millionths (things may be more advanced these days or quite possibly the equipment may still be used but rather has been enhanced by today's technology).
Going off in a little bit different direction, sometimes the clear chem film displays a blue tint which may be visible if a part is held at a slight incline. Lastly if all else fails and the parts permit, you can always strip the parts and reapply the clear coating and then you will know for sure the part is coated. Where you are is a difficult place to be in and numerous have walked this path before you.
supervisor - Cicero, Illinois
Saporito Finishing Co.
Q. We are trying to confirm the presence of a clear chromate conversion on an aluminum extrusion. Is there a simple chemical (or other) test that can confirm that the chromate is there? Specifically, the coating is per MIL-C-5541E Class 3, and the base metal is 6063-T5 aluminum. Is it possible to determine that it meets the class 3 thickness? We are trying to avoid the costs of outside material testing.
Mark Mozgowiec- Cambridge, Massachusetts
Q. My shop does chromating both clear and yellow.
Our testing indicates that we cannot meet the mil-spec with a clear coating.
At our shop we offer the customer the choice:
- they can have clear chromate, not certed to a spec or they can have yellow chromate with a cert
I know of no test you can do, BUT, I do know to get a truly clear coating you need to put on very light coating.
I would be interested in hearing if you find a test & if so, if your parts meet the mil-spec. I have posted this question here many times re: meeting MIL spec with clear chromate & some finishers respond that they do clear chromate & it does meet the spec - but no one referenced a specific QPL approved chemical to do this.
David A. Kraft- Long Island City, New York
A. Gentlemen,
I am an engineering student at a company that offers in-house chromating. Recently we've switched to a trivalent chromium to meet a new European directive that limits the use of hex chrome (among other heavy metals).
The problem I was facing with this new tri chromate is that the finish is practically invisible if no zinc plating is done previously. I was asked to find a simple test for the presence of chrome. Upon searching I found your site.
Our base alloy is 99% zinc so this might not work for aluminium. The process is as follows.
lead acetate Tri Hydrate [Pb(C2O3H2)2*3H2O]
Mix 50 g in about 1 litre of water. Filter for white precipitate or use acetic acid
[on
Amazon (adv.)] to dissolve. The solution should have a pH of 5.5 - 6.8
Place a drop of this solution on the part and wait 5 seconds. With a Q-tip
[affil links], gently blot.
A dark deposit or black stain equates NO COATING.
The Spec for this test is:
ASTM B201-80
I suggest reading that first and also obtaining a proper MSDS for Lead Acetate.
This test is for Zinc and Cadmium surfaces ... Perhaps it is worth an experiment.
Cheers,
JG
- Peterborough, Ontario, Canada
A. There is a newly developed trivalent chromium conversion coating two drop test kit on the market to detect the presence of Trivalent Chromium on aluminum substrates, Trivalent Tester LLC.
James Savoy- Columbia, Maryland
July 28, 2009
A. Dear Gentlemen,
Just make sure that your chromating solution is acidified to ensure that it is zinc chromate you are seeing on the galvanized material and not the aluminum oxide layer.
Regards.
Barlow Campano
galvanizing chemist - Jeddah, KSA
November 21, 2011
Is there any way to tell, other than visual, if a part has been Alodined?
Manufacturing Engineer - Wrentham, Massachusetts, USA
May 22, 2012
A. Hi Tino.
Alodine is a Henkel trade name for a line of chromate conversion coating products. Some are for zinc or cadmium plating, but you are probably thinking of chromate conversion coatings for aluminum. We appended your inquiry to a thread which may answer it.
A. There are test kits designed to indicate the presence of Chromate Conversion coatings. I know Chemetall makes one. As I understand, they work by forming Prussian Blue on the surface of the metal but chromate inhibits this reaction.
Scott Merritt- Eastman, Georgia, USA
July 11, 2012
A. There is a test on the market to detect the presence of type VI hexavalent chromate, but it does not work on non-hexavalent type II class 3 chromate.
The test product is ChromateCheck swabs by 3M. ⇨
I have contacted several companies that chromate metals and they all tell me there is no test for non-hexavalent type II class 3 chromate.
- Tinley Park, Illinois USA
August 12, 2015
Q. How to identify whether coating is trivalent chrome or hexavalent chrome (chromate conversion coated aluminum sample)? Is there any test for this identification?
K. Soni- HYDERABAD,TELANGANA, India
November 17, 2015
Hi Soni. We appended your inquiry to one of several threads on the subject. If you do not find all your answers on this page, you might also review:
thread 16365, "Determining if you have hexavalent or trivalent zinc chromate coating"
thread 35023, "Estimating levels of hexavalent chromium in plated metal parts"
thread 16365, "Hexavalent Chromium, how do I test for it on fasteners"
thread 38996, "Amount of hex-chrome in Conversion Coatings for Aluminum"
Q. Can you measure the thickness of a trivalent chromate topcoat over zinc? If not can you test for its presence?
Drew Howardsupplier - Rowlett, Texas, USA
April 11, 2017
Q. Greetings: We are a job shop metal finisher.
We are applying a clear, trivalent chromate conversion coating on sliver plated parts. Is there any test to qualify the presence of the chromate on the surface after it is applied to the silver plated surface.
Lab tech at plating company. - Phila., Pennsylvania ,USA
November 22, 2017
A. The best spot test for the presence of hexavalent chromium uses 1,5 diphenyl carbohydrazide. A suitable test (even though it is directed at coatings on zinc, cadmium and aluminum) is described in ISO 3613, Test Solution C ff. This test will work fine on silver. It is a pretty robust test.
Tom Rochester
CTO - Jackson, Michigan, USA
November 24, 2017
A. Hi David!
You need to certify that the trivalent chromate conversion coating is there? Or you need to check if there is any hex chrome in your conversion coating?
If you need the latter, ISO 3613 is the test you need. If you need to check if you have any conversion coating, you could do a test like DIN EN 15205 (BS EN 15205) with and without oxidation (presence of hex chrome after oxidation tells you have trivalent chrome). This test is longer and more tedious but gives you much more data.
Hope you can check your results! Best regards,
TEL - N FERRARIS - Cañuelas, Buenos Aires, Argentina
November 27, 2017
Q. I have a process for aluminum A360 we dichromate with Trivalent chromium and then we clean again the parts in ultrasonic washer.
My question is can the ultrasonic washer remove the trivalent chromium. My process is
1 almco steam washer
2 dichromate with this process
Aluminium degreaser
Rinse
Deoxidizer
Rinse
Rinse
Metalast rinse then
Ultrasonic washer
Impregnation
Quality supervisor - Sinaloa mexico
November 17, 2018
A. Hi Juan Carlos. Milt Stevenson asserts in thread 10002 that ultrasonic cleaning for any prolonged time will remove the chromate. But "individual results may vary", so we've appended your inquiry to this thread which discusses chromate testing, and where Daniel Montañés tells us (just above) how to check for the presence of trivalent chromate. Good luck.
A. In addition to Ted's comments, other factors that come into consideration include the temperature of your Ultrasonic cleaning solution (high temperatures are damaging to conversion coatings), and how soon after conversion coating a part is exposed to a hot solution (exposure just after conversion is more damaging than exposure after a few days). The chromium presence-absence test may give a false sense of security; while chromium may still be present, whether the coating has retained full corrosive protection properties must be determined by salt spray testing. I have personally seen samples pass the diphenyl carbohydrazide-peroxide test and still fail salt spray. Your performance goals for the finished part will determine how deep you need to dive into testing the results of your process.
Rachel Mackintosh
- Greenfield, Vermont
