Letter 17053
Electroplating metals
questions
What are two practical uses of electroplating and why do
we electroplate metals. What are electroplated metals used
for.
NAFATEERI pHAROH
- Guyana
Hi, Nafateeri. There are a half dozen different
electroplated metals in the computer you just typed your
question into -- including copper, nickel, tin, gold, and
usually some silver, palladium, and chromium. Some of this
electroplating is used for carrying current, some is for
corrosion resistance, and some for decorative reasons. So
two practical uses for electroplated metals are to allow you
to play video games and post your homework questions :-)
There's a starting point, and I suggest you continue your
research at the library. Good luck!
finishing.com
Brick, New Jersey
can you please tell me of some specific applications for
engineering in regards to electroplating?
josh m
- little rock, arkansas, america
There are countless examples, Josh M --
- Some alloys can be created only through
electroplating rather than by mixing molten metals.
- Components of certain types like ultrafine screening
and hollow gold jewelry can only be made by
electroplating.
- Electroplating also allows us to make parts of strong
flexible materials like steel, while having surfaces of
hard brittle materials like chromium or nickel-diamond
composites so that we can have molds and cutting tools
and machine parts and truck bumpers that will wear well
while not being subject to fracturing.
Take these terms and concepts to the library and see what
you can dig up. Good luck!
 Ted Mooney, P.E. finishing.com Brick, New Jersey
Hi, my name is Josh from Hollister Ca. and I was just wondering
what are some benefits of electroplating an item with a metal?
Josh F
Student - CA, United States
May 20, 2007
Hello, Josh F. Please phrase your question in a way that
demonstrates that you are reading the answers already
provided on this page. Thanks.
October 13, 2008
I am a senior student from the Bahamas, wondering if you
would be able to give me a detailed list of apparatus
required to copper plate an object. I've found bits and
pieces, including some on this website, but things such as
how much vinegar to use, how much salt, etc, are not
specified. I would appreciate this information, as it will
allow me to complete a chemistry project.
Treat J.
student - Bahamas
October 16, 2008
Hi, Treat. We give you a good idea on this stuff in our
FAQ: "How Electroplating
Works".
You should use full strength vinegar (it's already a very
mild acid, no sense in further diluting it). Add just a
pinch of salt (we explain why in the FAQ). But remember that
this demo is just to show you the principals; it isn't
really a practical way to electroplate (practical
electroplating requires proprietary and toxic chemicals).
Dear Reader, please --
- Answer or follow-up on this
subject (in non-commercial
fashion).
- Post a new
question on a different
subject.
