Corten Steel -- Q&A, Applications, Problems
Q. Corten staining its surroundings?
I want to follow up on the discussion of Corten steel in signs. I'm interested in using Corten as dimensional letters/graphics on a monument sign. As the material oxidizes to its stable state should I anticipate streaking on the face of the sign?
Gary Fedota- Atlanta, Georgia
May 28, 2008
A. Hi Gary. The runoff continues, and is a definite problem when buildings are put on concrete with no allowances for it. But whether it's enough to be a staining issue on the balance of your sign is harder to know. I suspect that if the sign is not absorbent, it's not going to be a problem.
Speed up Cor-Ten weathering process
Q. Can you please advise how a person can speed up the weathering process on Cor Ten steel to get the uniform rusted look. I have a customer fabricating a sculpture and would like the total surface rusted before placement. Can any chemical be used?
steel supply - Manistee, Michigan
A. A slightly acidic, iron chloride solution should work. Take a 5-gallon plastic pail, add some rusty steel scrap, 3 gallons of tap water, some salt and a gallon of hydrochloric (muriatic) acid. Let it react until the fizzing slows down, then apply to the sculpture with a paintbrush, polypropylene bristle broom, or similar. If dripping would be a problem in the location, use a polyethylene dropcloth. Let dry overnight, then hose off.
Ken Vlach [deceased]- Goleta, California
Finishing.com honored Ken for his countless carefully researched responses. He passed away May 14, 2015.
Q. I wondering if I could get the same results as Corten with any other metal? I am looking for some other product which give me the rusty look but no stain or at least not too much.
architect - NYC, New York
August 5, 2008
A. Hi Maria. I think a low grade of stainless steel, perhaps a 4xx, will work. Try soda blasting [soda blaster on eBay or Amazon (adv.)] it for evenness and to remove any passivation, then maybe wiping with diluted vinegar [in bulk on eBay or Amazon (adv.)] a few times over the course of a few days, then neutralizing with baking soda [in bulk on eBay or Amazon (adv.)] and a hard rinse.
Corten / weathering steel is only "better" in that it has very little expensive ingredients in it so it's very affordable. If the project can afford stainless steel, my bet is there will be far less staining.
Q. MY ISSUE IS A SIMPLE ONE. I HAVE USED CORTEN SQUARE TUBING, SQUARE BAR, AND FLAT BAR TO BUILD A BEAUTIFUL GAZEBO AND RAILING IN MY BACKYARD. IT HAS RUSTED TO A BEAUTIFUL DEEP REDDISH RUSTY COLOR THAT ONLY CORTEN CAN DO.
BUT IT CONTINUES TO DRIP RUST ONTO MY GRAY GRANITE PATIO, DISCOLORING AND STAINING IT. I DON'T KNOW IF I SHOULD NOW SEAL IT TO STOP FURTHER RUST DRIPS, WHETHER ANY TYPE OF SEALER SHOULD BE USED THAT WILL NOT DISCOLOR MY EFFORTS AND HOLD UP OVER THE YEARS, OR ANY OTHER SOLUTION TO MY PLIGHT. I WOULD APPRECIATE ANY AND ALL HELP.
LOUIS HOWARD- WESTPORT, Massachusetts
May 13, 2009
A. For people whose outside Corten sculpture is staining the patio below...I would suggest that you go with the flow (of rust off the Corten)...and stain concrete to a color as close to the Corten color as you can find...and then let the Corten be...as to sealing Corten...IMHO it defeats the purpose of the material...to create an oxidized layer that, supposedly, prevents further oxidation...speaking of which...how can it really prevent that if that rusty junk keeps flowing off? Isn't it, slowly, but continually oxidizing?...if you have to seal the Corten you are better off just painting "regular" steel
William McNally- Madison, Wisconsin USA
April 17, 2014
Q. Hi I saw a person rolling on what he called an Oil based smelly coat coat to seal that sexy rusty metal artwork.
What is it called? Please name a brand or two.
artist - Australia, Melbourne
July 9, 2009
Ed. note: Apologies, but we don't like to focus on brands ( huh? why?) -- but earlier on in the thread one reader suggested wax sealer
[on
Amazon (adv.)]; another reader suggested Permacoat Xtreme ⇨
followed by Masterclear ⇨
A. Lanolin based oil [on eBay or Amazon (adv.)]. May have to repeat every 6 months depending on exposure to weather.
Mark RekdahlMetal Refinisher - SAN BERNARDINO, California
October 29, 2021
Q. Has anything conclusive been offered in terms of stopping the rusting process of Corten?
I have a client who now likes the dark gray of the initial Corten state (and I do in this instance as well) and would like to know if there is some proven or tested method of removing what little rust that has formed and then seal it to remain as a raw, deep gray metal.
Thank you!
Mario
- Los Angeles, California
October 1, 2009
A. Hi Mario. We appended your inquiry to a thread which, if not offering a universal silver bullet, at least tells you what other people have been doing. But if you want it gray like normal steel, why use Corten? All clear coatings will deter rust, but none will permanently stop it. Good luck.
Q. I am looking for some Cor-Ten samples; including corrugated, and perforated.
Can anyone recommend a reputable company that will provide specs with the sample?
Any ideas for other interesting metals for exterior uses?
artist - NYC, New York
2008
Hi, Tim. Major national roofing companies will do this. But we can't offer brand or source suggestions ( huh? why?), sorry. Please google 'metal roofing supplier'
Sculpture
I love Corten steel for its color and turn it into women.
You get a kind of black color if you leave 2 pieces on top of each in a wet environment.
This is one of my women. Height 1.60 m.
sculptor - Holland
March 28, 2009
She's cold steel, but she's "smokin hot", Willemine :-)
Q. We have a metal sculpture fabricated in Core Ten that was graffitied. The only way we could remove the graffiti was with a wire brush which took us back to the bare metal. I know that eventually the patina will weather out but as this sculpture is "high visibility" and I know will get "hit": again, is there any way the bare surfaces can be treated to promote quicker oxidation.
Fred WestMarble West - South San Francisco, California USA
December 8, 2010
A. To obtain a quick patina on Cor-ten you can try to use some sulfuric acid [on
Amazon (adv.)]
or hydrochloric acid [on
Amazon (adv.)]. You will have a rusty surface within a day :-)
Careful when applying!
- Budapest, Hungary
February 3, 2011
Cortens in a Fountain ...
Q. Has anyone tried - or know of - using Corten Steel as a planter in a fountain? Wondering if it will completely corrode, or it will retain its structural integrity. The architect is using Corten and we'd like to stick with the same material.
Barry MillerDesign Studio - Miami, Florida
May 28, 2009
. . . which one will the fountain bless
Q. Greetings,
I am a licensed contractor specializing in water feature design and construction. Currently I am writing an article about one of the three projects we have worked on using Cor-Ten.
Please be so kind to answer the following questions I have not been able to answer.
1. I have Cor-Ten as a metal alloy, is there a better way of describing it?
2. Is it a type or cousin of Stainless? is it welded like stainless?
3. We made a 40'x60' perimeter of 3/4" Cor-Ten and I want to include the weight in the article. What is the approximate weight of a Cubic foot of Cor-ten?
In cooperation,
pond and fountains - Santa Rosa, California
May 31, 2009
A. Hi Jim. You seem to be the perfect person to answer the question immediately above yours if you have the time.
1. One reason stainless steel isn't used almost everywhere is cost. It's usually about 18% chromium and up to to 12% nickel, and those metals are quite expensive compared to iron/steel. Corten is "almost" plain steel, just a bit extra of some pretty standard ingredients in steel making, totaling under 3%. So its cost is closer to plain steel than to stainless steel. The best description may be "weathering steel".
2. It's welded like steel but with proper rods, and there are warnings that the weld zone may not patina like the rest unless some special things are done.
3. Like other steels, the approximate weight is .284 pounds per cubic inch.
Good luck with the article.
Q. I am an architect and have designed a fountain that has a rusted panel. We like the level of the rust in terms of a patina and want to keep at this level. If I apply oil to the surface should this suffice? If so, what type of oil should I use?
architect - Osaka, Japan
May 20, 2010
Q. I assume Corten has no fire rating? We want to use it as a facing on an external boundary wall situation which requires 30 minutes rating. Can it be mounted over a suitable rated board behind?
Dave Varneyarchitects - St Austell, Cornwall, England
February 16, 2010
A. Hi Dave. Corten is essentially steel, with a couple of percent of alloying materials -- so whatever that means in terms of fire rating :-)
Q. I have leased a building that has a large Corten fascia. The previous owner had large letters on the fascia. After removing the letters and wire brushing the surface, you can still see the out line of the letters. Is there a product to remove all the rust before applying new sign?
James DeGroff- Palm Desert, California USA
July 30, 2011
Bonding stuff to Corten
Q. If I want to construct a sign of Corten and have some acrylic plastic mounted inside of the steel, what bonding agent would be correct and what preparation to the steel would be correct?
Larry glickman- Portland Oregon
June 10, 2013
A. Hi Larry. Corten is essentially steel. There is little difference in composition. So I would suspect that soda or bead blasting is probably fine; you don't want to try to glue to rust. The right solvent for cleaning the plastic probably depends upon the type of plastic, but I think acetone [on eBay or Amazon (adv.)]would work if you don't overdo it (the acrylic may be soluble in acetone). There are lots of adhesives [adv: adhesive spray on eBay or Amazon (adv.)] but I don't like to say one is better since any of them should be fine.
Q. Can you drill CorTen plates and I beams? What is the best bit? I know go slow and use oil but any other tips would be appreciated. Thank you.
Lee Ann Pantalone- Bloomfield Hills, Michigan, USA
August 19, 2013
A. Hi Lee Ann. My understanding is that Corten is quite similar to plain old mild steel, so I don't think it work hardens, and advice about machining mild steel probably applies to Corten. Yes, I think it's easily drilled and doesn't require exotic drill bits.
Q. I have Corten fencing around my home which is rusted and the look we want to keep. Have noticed we are getting marks on it..from bird droppings and cats paws, as well as oily markings from people who push the gate to open it.
How can I get it to return to the rust in these areas?
Any advice would be greatly appreciated :)
- Melbourne, Australia
October 7, 2013
Q. Hi, I was wondering if it's possible to purchase corten rivets or screws for fixing corten?!
Cheers Grant.
Owner Builder - Rye Victoria, Australia
November 26, 2013
Q. Hi, My name is Deanne and I am a Community Strategies Coordinator involved in heritage programs and projects for the region. One such project is the installation of heritage plaques throughout our community. we have installed 14 plaques in 2013 and noticed that many of them are not oxidizing uniformly. There appears to be rust stains along the bottom as well as rust 'runs' down the front of the steel.
Is this a natural part of the transformation of the patina or is something else occurring that we need to take action on? I thank you in advance for any information or advice you may offer.
Regional Municipality of Wood Buffalo - Fort McMurray, Alberta, Canada
April 11, 2014
A. Hi Deanne. We appended your question to a thread which may answer it for you. Please see the 'Achieving even rusting' subheading; it suggests abrasive blasting. If you were to use soda blasting or dry ice blasting, it should be safe with little or no cleanup. Good luck.
A. The "pattern" of rusting is highly subject to environmental conditions. Blotches can come from spills of various sorts, vertical streaks from dripping water, etc. It's also generally not a totally uniform process.
If those are steel plates supporting those plaques, then what is shown in the photos is about what I'd expect after a year or two of sitting outside. You can take action if you don't like the way it looks, but if the question is just between "is this normal?" and "is something goofy happening?" I would go with "normal".
If those are stainless steel plates, you have a major problem and they should be cleaned up and passivated immediately.
Ray Kremer
Stellar Solutions, Inc.
McHenry, Illinois
April 22, 2014
Q. I am considering using Corten as a garden wall between a hedge and an herbaceous border. Does anyone know if any of its properties can damage plants? Thank you.
Annie Rhodes- Borders, Sotland
May 5, 2014
A. Hi Annie. The earth is 5% iron, so the dirt already has rust in it; your plants will be fine. As an aside, to help people understand what Corten is about: although stainless steel would rust much less than plain steel, it is way more expensive, and looks very different ... so it's impractical for a lot of applications.
But people have known for a long time that the rust on plain steel is hygroscopic, fluffy, and poorly adherent, which leads to continuing rust and corrosion. So the researchers at US Steel asked themselves whether it was possible to make some fairly small adjustments to the formulation which would be quite inexpensive and which would have little effect on the properties of the steel itself, but which would improve the adhesion of the surface rust and reduce its porosity in order to substantially slow down the rusting ... Corten or "weathering steel" is the tweak that they came up with.
Thank you very much indeed Ted.
Annie Rhodes [returning]- Borders Scotland
Q. I am looking to put up a small privacy wall 17' x 24"- what thickness of corten do I need to use? also can I just dig some footings and pour concrete with metal poles to weld to the back of the corten sheet or do I need to bury any of the metal.
Donna Castle- Dallas, Texas USA
June 2, 2014
A. Hi Donna. Your questions require engineering work and are not easily dispatched -- which is not to say that experienced tradespersons can't play it by ear to a workable answer; they do so all the time.
Although corrugated roofing panels of the thinnest gauge commercially available will be quite strong against bending, a moderate wind will exert a good force on something 17 foot long x 24 inches high. But if you put in 5 support posts, so the span is 4' 3", it will probably prove practical. The steel posts will last longer and work better if set in concrete than if driven directly into the ground.
