Bluing steel
In order to "blue" steel, what type of oil (if any) should be used? Am I correct in assuming an "oily rag" would be sufficient to do the job? What temperature does the steel need to be in order to obtain the best effect?
Pierre Charbonneau
- Limehouse, Ontario, Canada
Pierre,
Regular "hot" bluing is done with a caustic soda [affil links] solution (or others) of around 300 °F. Some "case hardening" is done by heating the metal and quenching in oil, but this will normally produce various colors on the metal. I hope this helps.
Ed Kay
- St. Louis, Missouri, USA
