Cement Statues for Garden
I bought unpainted cement statues for the garden in Missouri. I have been to 3 craft stores (in the Chicago area) and can't get any information on what kind of primers or paints to use. I would be grateful if you could tell me what kind of primer and what kind of paint to use.
Thank-you,
Darlene Wolf- Franklin Pk, Illinois, USA
I basically have the same question as to what primer or masonry sealer and paint I should use. My statue is painted already, but the paint is popping off. I don't think the statue was seasoned or sealed to begin with. I already have the stripping solution for masonry. Please let me know what to use and the procedures.
Deborah B. Bayol- Reston, Virginia
Hi. I worked for a shop owner in Hartville painting cement statues for people. I cannot remember the name of the primer, but I used a masonry primer. I first cleaned the cement well, let it fully dry and then applied the primer. I did not like working with oil based paints, and used acrylics ... however, I believe oil based paints would serve you better. When I was finished, I sprayed the entire piece with Marine Spar Varnish. I hope this helps.
Rebecca Williams- Hartville, Ohio, USA
I want to paint a cement dog, but cannot find the acrylics I need in a large or pint size. So sure could use some help I went to a paint store last and they had me buying about 5 different Paints . NO I don't think so. There has to be a easier and cheaper way to do this. Thank you
Jackie Bristow- Lubbock, Texas
I love to paint cement statues and have been doing so for more than 25 years.
I use
Deco Art Patio Paint
[affil links], check at a craft store. (they have a clear coat, which you put on first, then the paint and then the coat again) if you are doing a small statue, this is a great way to go.
I also use acrylics & I will mix them with the patio paints--to get other colors;
I use some masonry paints (but you have to buy in bigger containers) but you can also mix acrylic paints with them & get other colors
(Walmart has an exterior paint that is great & you can get great colors); mccloskeys is also a masonry paint base--check your Walmart--this is where I first discovered it for a great price.
I have used Rustoleum once and 18 years later, its never needed painting again--but its in shade and somewhat protected.
I used to use spar varnish--a marine boat varnish--on anything not white--it yellows, but in the past year I have had problems with it flaking.
We now use Cure Coat--which we found at a home improvement center--but also discovered at one of the local paint stores. cure coat is a masonry/cement/brick sealer. cure coat cleans up with warm soapy water.
I also use a cement sealer, that cleans up with
lacquer thinner [on
Amazon (adv.)] --both seem to work fine.
We use a cement/masonry primer--also cleans up with lacquer thinner [on
Amazon (adv.)]--once its dry--usually an hour or so--you can start painting.
If the paint is flaking from another paint job--you should remove the flakes--but I've never stripped the whole statue down--its a personal choice tho.
If your statue has been sitting out in the yard and getting lots of weather for more than 6 months--my father-in-law told me an old painters trick was to wash the statue down in bleach
[adv: bleach/sodium hypochlorite in bulk on
Amazon (adv.)]
--let it soak in, and then wipe off and let it dry; your primer and paint should then stick.
Hope this gives you some ideas.
- Grants Pass, Oregon
I own a retail nursery and would like to carry a group of cement figurines that I cannot seem to locate the source. The size is approximately 15 inches with old looking paint. The figure I have seen is sitting and playing the picolo. Anybody have any ideas about who makes this product?
Dirk Winterseller - Cambria, California, USA
August 25, 2008
Try Continental Craft , located in Chicago.
Michael Partipilo- Chicago, Illinois, U.S.A.
January 19, 2012
