The market for nickel plated steel strip
Can you recommend any resources that would report on the market for nickel plated steel strip in the United States?
Best regards,
Rob Babson
Inco or the Nickel Institute may have that information and might give it or sell the documents.
Hi Bob, how are you? This is the way we meet again! One of the markets you are looking for, I think, is the rapid discharge lead acid battery manufacturing. Subsequent to nickel, they plate lead. These are used as triggers for amunition. But they are slowly moving towards the lithium batteries. Why, I forgot.
Mandar Sunthankar
- Fort Collins, Colorado
Using the pre-annealing process, what would cause nickel plated steel to blister if the hardness is 85 Vickers?
Zanele Mzinyati
Zaire
