Teflon and molybdenum coatings before or after nickel plating
Dear Sir,
On our component, we have to carry out 'viton' rubber moulding on the steel substrate (low carbon); after moulding we have to do nickel plating on the outer diameter of the steel substrate (not on the inner diameter).
Thing is we have to do the 'teflon' & 'molybdenum' coatings on the rubber mould part, which would be the ideal process sequence to be done. That is teflon & molybdenum coatings before nickel plating or after the nickel plating?
Also, kindly send us the technical details on the teflon and molybdenum coatings.
Kindly do the needful.
S. SENTHIL VELAN
- COIMBATORE, TAMIL NADU & INDIA
You must to make the nickel first and after the Teflon coating. Normally the Teflon molybdenum coating cures at 220° C, and do not affect at the nickel.
Yours,
Jordi Pujol
FISA RECUBRIMIENTOS - Barcelona, SPAIN
