RHR to Ra, Rz conversion
I have an aircraft service bulletin that requires an inspection of an aluminum surface for roughness. It states that the surface can not exceed 125 RHR (Roughness Height Reading). My surface finish roughness gauge only has two scales: Ra and Rz. Does anyone know if there is a conversion from RHR to Ra or Rz?
Mark Thibault- Dhahran, Saudi Arabia
RHR is an older notation to express Ra. It usually was expressed as single value or a min to max Ra range. Bill Boatright- Morrisville, North Carolina Rz is the measurement of the Average Peak to valley height. You need to be able to measure Ry which is the maximum height of the profile. ![]() George Shahin Atotech - Rock Hill, South Carolina |
There is a site which discusses converting surface roughness numbers. The site is at
www.qualitymag.com/execute.asp?SideBar=Active&Cat;=4&Section;=Articles⋐=Detail&rID;=D2021CDB707E430BAE85DE26A55467F5
The article is titled,"Apples, Oranges and Surface Finish Parameters".
This article relates to the standard DIN 4768-1978 for approximate conversions. The article may provide some assistance.
Matt Hogan- Australia
From what I read on the web, RHR exactly converts to Ra (average), the new American standard. Rz (mean) is the new Euorpean standard.
Gerald Maurer- Kingston, WA , USA
