Using citric acid as an Electrolyte
I currently have a passivation line in-house using citric acid . Is it possible to use this as an electrolyte for electropolishing as well? If so, what are the parameters with regards to voltage, temperature, etc.
Don Clifford
Antron Engineering - Bellingham, Massachusetts
No. It is not good, as a general rule, to mix uses of tanks, and probably impossible that most would just happen to have the same concentration, and the same tolerance to impurities.
