Safety of open fire barbecue with galvanized mesh
Q. I have built a small Hibachi Grill and use some yellow zinc rivet nuts to hold some brass screws. I have also plated a Damper with yellow zinc. I know Zinc degrades over a certain temperature but wanted to know if anything harmful was happening with the zinc material i.e. Food contamination. none of the parts are in direct contact with food, just food adjacent. any help on this is appreciated.
- Humboldt Kansas
September 21, 2022
A. Hi Dirk. You're dealing with both chromate and zinc. My personal opinion is you should have a hot fire in it at least once before you put food in it.
Q. Please let me know whether there is any hazard in using galvanized mesh over the open fire for barbecue. Will the fume or any substance from the Galvanized mesh in direct contact with the food while burning, contaminate the food such as steak or fish?
David Wong- Melbourne, Victoria, Australia
A. Hi, David. If you are a manufacturer, you would want to nickel plate or ceramic coat, not galvanize, the components ... because zinc is not considered a food-safe surface, plus it is usually chromated, and chromate is toxic. So the following assumes that you are an individual building one grill for yourself --
Zinc is an essential micronutrient, not a cumulatively toxic metal like cadmium, mercury, or lead; but are you sure it is actually zinc galvanizing, not a piece of cadmium plated scrap? When you use things for purposes for which they weren't intended, you may have the situation that you don't really know what they are. Further, there usually are no research studies of such things, so you are not going to get facts, only an educated guess (although on rare occasion you can find a WHO or similar report if you search hard and if the practice is widespread in the 3rd world).
Most things are a matter of degree. It is not considered a idea to eat food off of a zinc surface, and I'd certainly be leery of it the first time something was cooked on it, but if it struck me as the practical way to build this one-off thing for myself, I'd probably get the fire and grill good and hot, then wire brush and detergent wash the grill after this initial exposure to the heat, then go with it. But we're speaking personal philosophy only -- I'm no medical authority.
Q. I am building a bar-b-que in my backyard. I have some sheets of 18 gauge galvanized metal that I acquired and would like to use them as access doors. The access doors will include a door to the ash pit, a door to put in charcoals, a door to a brick smoker and the cover for the grill portion of the brick pit. Also there is a 99% chance that I will be painting these door with the high temperature paint
[affil links]. Reading all the information so far posted on your site, I have not yet come to a safe conclusion in my case.
Can you please help to enlighten me on my project. If I haven't been clear with my scenario, maybe this will help. Will the galvanize steel be a danger to the health of my family? Will painting the metal decrease the danger? Do you recommend painting the metal that will be within the confines of the cooking parts. Such as under the grill lid and inside the smoker and charcoal access doors.
Dj AdamsHandywork - Sacramento, California, USA
A. Nobody can tell you, sight unseen, how safe a home project is. But OEMs sometimes use zinc plated and galvanized materials in components (but not grates) of grills and barbecues, and I personally don't know of any evidence to suggest that an untested paint will prove safer than zinc.
Q. Back Yard Barbecue
For years we have been using a "pig holder" made with galvanized steel poles, flat reinforcement bars, and chain link fabric on a homemade concrete block barbecue. The pig is butterflied and laid flat between two panels -- creating a sandwich that holds the pig in place and allows it to be flipped during the cooking process.
We have done this for years with no ill effects -- at least none that we know of. Now we hear that galvanized metal should NOT be used on cooking surfaces. Is there a way to burn off the coating before use? Could we grind off the coating from the flat support bars and use an aluminum or aluminum-coated steel chain link fabric for our mesh? (Only the chain link fabric and the support bars touch the meat, and only in a limited way.) Is there any other type of chain link or wire mesh material that would be more suitable? No axe to grind here -- we just don't want anyone getting sick at one of our parties.
Thanks for your help!
Glenn Lindgrenbarbecue - Eagan, Minnesota, USA
Q. I have recently switched to hardwood in my B.B.Q instead of propane or charcoal.The problem is the ash and small pieces of wood fall through the bottom of my B.B.Q. Would I be able to use a galvanized steel mesh on the bottom of the B.B.Q to catch the embers?
The steel would not come in contact with the food but I wonder if the heat from the flame would affect the finish and any chemicals would leech into the food anyway ?
Consumer/handyman - Laval, Quebec, Canada
A. Hi, Glenn. We appended your inquiry to a very similar one which has already been answered. Yes, aluminum coated fencing would probably be preferable if available, and stainless steel would be perfect; but, if not, burning off the galvanizing would be sufficient for me personally.
Hi, Victor. I personally wouldn't worry about such minimal use of zinc. But again, I'm just the curator of this metal finishing site, certainly not an epidemiologist or medical authority :-)
Q. This is a Hobbyist type question. I do a lot of outdoor cooking and BBQing. I recently purchased a 4' X 8' sheet of expanded metal to serve as a cooking grate. The metal came with a tag that warned of dust and vapor from welding, burning and cutting. I use only non-coated common steel pieces for cooking or BBQing. However, I noticed that the tag also warned of trace amounts of Lead and other heavy metals. I always wear particle and dust masks along with other PPE while burning, cutting, grinding or welding. Now I am interested in any harmful vapors or metals that can enter food while using these metal grates for cooking. BBQers are always instructed to season their equipment (and I do) for corrosion protection. Does this also help with any off-gassing? Also. The temps that are used in the cooking process are well below melt points. Most Hobbyists cook between 225 °F and 350 °F.
Is there any harm from using any specific metals for these purposes? For instance, I use mild steel walk way grating as cooking grates. I also use common non-coated steel angle iron and expanded metal for the same purposes. Should I be worried? Any precautions?
hobbyist - Trinity, Alabama
May 18, 2009
A. Hi, Lendon. If the supplier's lawyers or a government agency felt it was advisable to label this metal and to warn you of the dangers of welding, burning, or cutting it, sorry but it just isn't reasonable to expect a third party -- who doesn't even know exactly what it is -- to assure you that, not only are the labels wrong, but it's even okay to eat off of it; sorry, no can do :-)
Sorry, and Regards,
Q. I want to use a galvanized steel ring (36" diameter/ 8" height) as a fire pit ring and I am concerned about the toxicity of the galvanized metal when regularly introduced to the heat of a fire. is it safe to uses as a fire pit ring? If it is, is it still safe to use if the kids are cooking hot dogs and roasting marshmallows? Most of the time I love my kids - don't want to poison them? Not yet at least. Thanks.
Arthur szczokotcontractor - Toronto, Ontario, Canada
June 3, 2010
Hi, Arthur. I've repeatedly offered my personal opinion on this thread, and on dozens of similar threads. It's time for someone else to give their take on it, rather than me just offering ever finer, ever more subtle, nuances on what is just my individual personal opinion and personal philosophy of living :-)
Good luck and Regards,
Q. Hey, I have built a sausage smoker out of galvanized iron. I just wanted to know if I put an open fire in the smoker to burn of any toxic stuff. Is it then alright for me to use or should I just change the sheeting and be done with it?
Harry Foundas- South Australia
June 19, 2012
Q. I have wrapped the outside of my fire ring with light gauge aluminum. will it give off harmful vapors?
Jim Wilson- Beaver Falls Pennsylvania USA
July 20, 2012
A. Hi Jim. Countless people throw their aluminum beer cans in the outdoor wood camp fire and cook on it the next day, and I personally haven't yet heard of it being a problem.
Q. I WOULD LIKE TO KNOW IF IT IS SAFE TO USE GALVANIZED METAL AS AN ASH TRAY FOR MY SMOKER.
Jose Carrizalweekend outdoor cook - Baytown Texas
November 1, 2014
A. Hi Jose. The ash tray on my wood stove is galvanized metal. That's not the same thing, but about all I can say.
November 2014
Galvanized aluminum and grilling
Q. I recently used a piece of galvanized aluminum left from duct work to line and cover a hole in the bottom of my grill. The charcoal grates were about four inches above this sheet of aluminum obviously holding the charcoal. Is there a risk that the food was contaminated and if so what would have been the symptoms for those that consumed the food and finally would this exposure be something to see a doctor for? Thanks for your help, feeling very stupid for using the aluminum, Tobias.
Tobias SchirmerHobbyist - Belleville, Illinois
March 4, 2015
A. Hi Tobias. I'm confused regarding what you think the material is. Galvanized duct work would be steel sheet metal with a coating of zinc on it. There is such a thing as aluminized metal, which is steel with a coating of aluminum on it, but it's less common and I doubt that the duct work was made out of it. Some ductwork is also made of aluminum instead of galvanized steel.
People often wrap their corn, potatoes, fish, and other foods in aluminum foil for grilling, so certainly there is no issue with aluminum. But as said above, it's a bad idea to use materials in food preparation that weren't intended for the purpose ... still, I don't really imagine this galvanized ductwork liner, covering a hole, did any harm to anyone. Zinc is an essential micronutrient, not a poison.
Although ANYthing is possible, food poisoning is just such a common thing at picnic/barbeques that it seems better to me to carefully focus on what was done with the food that may have led to it and should be avoided next time.
March 2015
Please Note>>
According to Wikipedia, Zinc IS poisonous if an excess amount is present in the human body...
Even though zinc is an essential requirement for a healthy body, excess zinc can be harmful, and cause zinc toxicity. Such toxicity levels have been seen to occur at ingestion of greater than 225 mg of Zinc. Excessive absorption of zinc can suppress copper and iron absorption.
Zinc toxicity .
Thank you, and God Bless - Safe & Happy grilling this summer everyone!
- Birmingham, Alabama USA
June 16, 2015
Yes, of course, Bartholemew. Paracelsus doubled down on that idea 500 years ago with "Poison is in everything, and no thing is without poison. The dosage makes it either a poison or a remedy.
A. If you have any concerns about zinc, buy what surface you want to use at a farm supply place, like Fleet Farm or TSC; their galvanized steel products are usually "hot-dipped galvanized" which you can recognize by the "feathery" appearance to the coating (instead of a smooth surface) that only hot-dipped galvanized zinc has. It is easy (and can be either fun or dangerous) to remove the galvanizing with DILUTED Muriatic acid (add one part acid to 6-10 parts COLD water. Do not add the WATER TO the ACID. Do NOT use hot water. It will bubble like crazy (GOGGLES) and etch off the zinc but the bubbling slows way down when only the iron is left. The bubbles are hydrogen gas so no open flames or sparks. Been there, done that. Got the singed hair to show for it.
BTW: why mix the two that way? It CAN can very hot very fast if they mix too fast. Which do you want spraying up in your face? Hot water with some acid in it? Or hot acid with some water in it?
science teacher - Ely, Minnesota usa
November 10, 2016
Q. Hello, my question is, Is it safe to use nickel plated or zinc plated tubing as a smoke stack for my BBQ smoker grill that I'm building,
Eric Coramequipment maint. - Washington dc
February 21, 2017
Q. Hi. I recently bought a small (2x2) square sheet of zinc coated steel to place over a rusty portion of my smoker box. I have sanded it, but my question is, is sanding enough to remove the zinc coating. I'm worried about the heat causing fumes that could contaminate the food. Any help is really appreciated.
Raymond Tannock- Somers Point, New Jersey
March 25, 2017
A. Hi Raymond. Not to worry. Your question can sort of be compared to asking whether taking a baby aspirin is safe since we know that swallowing a bottleful of aspirin is dangerous. Zinc is an essential micronutrient, not a toxin. The "zinc problem" affects welders and others who heat large quantities of zinc to its vaporization point and then inhale the resulting clouds of fumes and suffer an overdose.
A. Galvanized (zinc coated) steel is a problem only under specific circumstances, and the problem in a grill is if you've met those circumstances.
Yes, zinc is a micronutrient that your body does need in some quantity (and will ward off/kill viruses in your body in small quantities). The problem is not really short term contact with it (though the water coming off of tin roofs with zinc coatings will kill the grass it comes in contact with), and I ended up here trying to figure out if it's a problem using galvanized parts for grill burners.
The problem is that galvanizing gives off very toxic fumes if you get it hot enough, like when you weld it with an electric (MIG Or TIG) process. You get white, sweet smelling fumes and the zinc surface turns to a light white powder. Breathing in even a small amount of these fumes will get you pretty sick and in the hospital the next day with neurologic and gastrointestinal issues and could kill you. Supposedly drinking a lot of milk after exposure can help.
If you don't get it hot enough for the zinc to burn off the steel you shouldn't have any problems. Exposing it to a few hundred degrees like a wall or a baffle in a smoker is no big deal, and if you're really concerned about it anything that will outgas will likely do it the first time you heat it up (unless you at some later time get it glowing hot). Be aware that if you get it hot enough to burn of the zinc you need to get the powdery white residue off with a brush, and you're left with bare steel that will rust quickly. If you have other bits that you just want to get the stuff off the best/fastest is to just soak it in muriatic acid (you can get it at the hardware store for etching concrete and cleaning some things)
For the person worried about if he should go to the doctor to get checked out it could never hurt (*I'm not a doctor and don't take this as medical advice so don't sue me*) but if you were suffering from acute zinc poisoning you would have been acting weird enough or worse that you would have been taken to the hospital in an ambulance. I wouldn't worry about it a few days later if you're still feeling OK.
In my case, I want to build some burner parts for a custom propane burner out of galvanized steel (either galvanized conduit or pipe). Something that will get significantly hotter than most of the parts that you guys are talking about. I suspect that the parts will be OK but I'm not positive. I do know that cheaper grills come with "galvanized" burners, but I'm not positive if they are truly galvanized or if they're actually aluminized.
Aluminized steel is a thing, it's coated with a light coat of aluminum rather than zinc, typically it's nowhere near as heavy and it's hard to tell. In a lot of ways it looks like bare steel that stays somewhat bright rather than going rusty right away, something in between the look of steel and a really light galvanized coating. For the most part the only place I know of that it is used for sure is in non-stainless exhaust tubing/parts. It makes them last a little longer, you can burn right through it with a welder and is not toxic when welded over.
- Laurel, Maryland, USA
Q. Can use some help here. I've got an old fuel tank that's been cut to use as a chicken cooker. The racks I have were originally used for cooking a whole pig on it. To cook chicken I have some chicken fencing I'm going to use to assure that the chicken don't fall through the holes in the rack. Is chicken wire fencing safe to use this for? Got me worried.?
Jonathan mcgibbon- youngsville New York USA
August 19, 2017
A. Hi Jonathan. You're repurposing an old fuel tank which was full of poison, without knowing what surface treatments it received and not knowing what they may do if heated as well, but you're worried about chicken wire giving off fumes when heated...
Actually the first problem with the chicken wire is that it's not considered a "food-safe" surface (a surface upon which it's safe to place food), whether heated or not. Please see if it is possible to get some stainless steel wire cloth; it's a better answer in all regards. Good luck.
Q. I would like to know how they can sell park-style BBQs that have been hot dipped after fabrication if it is any way dangerous? Thanks.
Hendri Marais- Qld Australia
October 1, 2017
⇦ (tip: readers usually show little interest in abstract questions,
but your actual situation will usually bring responses)
? Hi Hendri. I don't know who "they" are who is selling them, what parts are galvanized, nor what organization you feel should outlaw it, etc. But I personally would not put food directly on a BBQ grate in a public park regardless of what it was made of. I'm sure that drunken teenagers pee on them and worse.
Are you a consumer who bought one for home use or an engineer for a rival company or what? Please introduce yourself and the situation because abstract questions are rarely answered usefully :-(
September 2017
Q. I have galvanized flame covers that fit over the gas burners on my grill/bbq. They are shaped like pitched roofs and sit directly over the flame to keep grease from dripping onto the burner. I noticed that they developed a white powder on them (I think it might be white rust?) and I decided to try and scrub/wash them in my kitchen sink. Once I submerged them in water, it turned a green-yellow color (similar to antifreeze, gatorade or mountain dew). No matter how much I scrubbed and how many times I rinsed them, there's still this green-yellow residue left over in my sink and on any paper towel I use to dry them with. Is this a potentially hazardous risk? Should I stop cooking with these components? I am worried that these are toxic.
Kawika Lanakeha- Seattle, Washington, USA
June 25, 2019
Metal roofing/siding used as cover over BBQ
Q. I made a block grill. Below the grate is 14" and there is 8" above the grate.Can I use metal roofing to hold in heat and smoke when grilling chickens, ribs, etc. at MAX temp of 350 °F ? Concerned about zinc coating.
Richard Ondrey- Patoka, Indiana, USA
September 25, 2019
A. Hi Richard, we're starting to run in circles after twenty seven previous postings on this thread, but ...
When you use something for a purpose for which it was not intended we can almost never say it's "safe" because the designer never intended for it to be safe for this purpose, and we have no idea of his thought process in making design choices, and we're not even 100% sure what it is (You're concerned about the zinc, but are you sure it even is zinc? What is the post-treatment -- chromate, silicate, some new nano-coating, a clear coating, who knows?); plus, we have no governmental agency regulating it, and we have no epidemiologists studying it. Nobody can positively assure you it's safe. But if food is not in contact with it, and it never gets truly hot, it becomes a question of personal philosophy :-)
I personally would use it, but others might not.
September 2019
I am trying to repair my propane grill and found your thread on metals used by others, I learned ideas and my concerns addressed, thank you.
c c villanuevahobbyist - san antonio texas
February 20, 2022
