Anodized finish removal from aluminum
What is the simplest process to remove an anodized finish from aluminum other than sanding it out? Once the finish is removed and buffed to a high luster, what is the best way to protect the shine from corrosion?
Dewey Sammons- East Point, KY, US
The easiest way is to take it to an anodizing or plating shop which can strip it the right way in chromic-phosphoric acid. Second easiest is oven cleaner [on eBay or Amazon (adv.)], but I would not guarantee that an inexperienced user wouldn't dull, pit, and ruin his parts. (Plus it's dangerous). The way to lock in the shine is to anodize again, although a clear lacquer coating may be good enough.
