Hard chroming process
I would like to know if anyone could tell me if it is possible to hard chrome a crankshaft of a rockwell hardness of 55 rc while it is still inside the engine. This is to repair connecting rod journals on locomotive engines.
Thank you for a reply,
Archie Hebert
a diesel service - Thibodaux, Louisiana, U.S.A
Archie,
I would not recommended hard chromium in this case. Yes it is simple to build a tank around a part and plate it. But when you have a hardness on 55 HRC you must shotpeen the crank before hard chromium. If you not there is a possible at the part will show a hard chromium plating with cracks on the surface. Also how will you remove the hydrogen embrittlement? It should be 142 °C for 12 hours after plating when you have a carburized steel.
Anders Sundman
Anders Sundman
Consultant - Arvika,
Sweden
In theory, absolutely. Talk to 'brush plating' suppliers like Gold Touch [a finishing.com supporting advertiser] and Sifco. Their customers do this kind of thing all the time. However, you may find that nickel plating is preferable to chrome plating.
