Coating questions - poor zinc coverage on edges
I need to ask only couple of questions.
a. we have done many cable tray and cables ladders and other electrical power angles and other more stuff which all was required 110 Microns our zinc consumption became 7 to 9 % is this right consumption?
b. we are facing problem to have coating on edges of beams flanges other area of the same having quite good coating, if we go increase our immersion time to having coating on the edges then other part of that particular material getting thick coating, Since its hard for us to regalvanize we are matching the standard coating by prime zinc spray.
"Hot Dip Galvanizing of Steel Structures"
by Kuklik & Kudlacek
galv_structures2016
or eBay or
"Handbook of Hot Dip Galvanization"
by Maass & Peissker
galv_hot_dip_handbook2011
or eBay or
Please rush reply.
Muhammed Babar
galvanizing. - Al-Khober, Saudi Arabia
Assuming hot dip galvanising:
(1) Make parts cathodic (-6 Volts) and make tank anodic. This encourages higher deposition on sharp edges.
OR
(2) Reduce temperature to increase viscosity
John Tuohy
- Ireland
