Electroplating of plastic
I am engaged in electroplating of plastic. Presently I use electroless copper to make it conductive prior to electroplating. I have come to know that some new technique has been developed in which no electroless metal plating is required. After activation in palladium chloride solution it is treated in some type of Cu / Pd solution. It makes the plastic conductive without any visible copper coating. Then it can be electroplated in the conventional manner. If anyone can help me I'll be highly grateful to him.
Zafar Mahmud
Z.M. Traders - LAHORE, Pakistan
Dear sir,
I have heard these systems. There are few commercial system like this call "direct plating". What supplier nationality you use their system (Japan or USA) and what kind of help do you want to?
Best regard,
Prasarn Hutpattanasilp
LorYongSeng Co.,ltd. - Samutsakorn Center, Thailand
