Bright brass refinishing
I originally purchased solid brass door hardware which is now very dull. The mfg. told me to remove the lacquer, polish with a very fine #0000 steel wool [on eBay or Amazon (adv.)] and spray with a brass lacquer [on eBay or Amazon (adv.)] . I did all this BUT I would like to know how to get a very bright polished look and a very durable lacquer coating.
Gordon H [last name deleted for privacy by Editor]- Mukilteo, Washington
I hate to argue with the manufacturer, who should know better than any of us, but I don't know that fine #0000 steel wool [on eBay or Amazon (adv.)] is enough to restore a bright brass look. I think you need to buff with Brasso [on eBay or Amazon (adv.)], Twinkle brass & copper [affil links], Copper Glo [affil links] or some other compound after the steel wool step. Then lacquer. The more patience you have in terms of multiple thin coats, the better. There are copper/brass specialists like G.J. Nikolas [a finishing.com supporting advertiser] who may be able to offer a lacquer well tailored to the specific use.
Hello Gordon,
If you look around the internet, you can find suppliers of polishing compound and buffing wheels, some that attach to a drill. Maybe polishing the brass with an abrasive polish like Brasso would do. Whatever you decide to do, wipe the part down with lacquer thinner [on eBay or Amazon (adv.)] prior to lacquering. If you want a durable lacquer finish, maybe go with a higher quality lacquer rather than a cheap one (you get what you pay for).
Best of luck,
Jake KochG. J. Nikolas &Co.,Inc.
Bellwood, Illinois
