MASKING
HELLO,
I AM INQUIRING ABOUT A CERTAIN TYPE OF LIQUID MASKING OR MASKING TAPE THAT COULD BE USED TO MASK OFF AN ALREADY NICKEL PLATED PART THAT NEEDS TO BE RE-ANODIZED? MY CUSTOMER HAS USED QUITE A FEW PRODUCTS AND HASN'T FOUND ANYTHING THAT WILL HOLD ONTO THE NICKEL PLATED PARTS. WOULD YOU HAVE ANY SUGGESTIONS?
I ALSO HAVE MINIMAL KNOWLEDGE ON CONDUCTIVE ANODIZING. THE SAME CUSTOMER IS USING A 3 MIL LEAD FOIL TAPE WITH RUBBER ADHESIVE AND CLAIMS ON THE CONDUCTIVE AREAS THE LEAD FILM IS BURNING? I DIDN'T THINK ANODIZING HAD HIGH TEMPS, AM I WRONG? PLEASE HELP.
THANK YOU,
LISA C. [last name deleted for privacy by Editor]
- Racine, Wisconsin
www.finishing.com/chemicals/
Go to this page, and search for 'masking'. There are about 5 companies there who may have the technique for which you are searching.
