Letter 11064
Surface treatment for magnesium
A housing consists of several die-cast magnesium parts. The parts are yellow chromated acc. to DIN50939. The housing comply with EMC requirements. At high humidity and temperature the corrosion protection of the surface treatment is not sufficient anymore. This causes EMC problems. What is a better surface treatment??
Jerry Roctus
Thomson multimedia - Breda, The Netherlands
Have you considered anodizing? This process can be done on magnesium, not just aluminum, and may give you better results.
Tim Neveau
- Rochester Hills, MI
Another possibility often employed today is electroless nickel plating of the magnesium.
finishing.com Inc. - Brick, NJ
Dear Reader, please --
Post a question on a different subject.
List of Directories
Link to Del.icio.us button Save This Page (why?)    -    Home    -    ©1995-2008 finishing.com
