Cleaning or darkening the galvanized steel prior to powder coating
"Phosphating of Metals"
by Werner Rausch
phos_rausch1991
or eBay or
"Handbook of Hot Dip Galvanization"
by Maass & Peissker
galv_hot_dip_handbook2011
or eBay or
I would like to paint some galvanized steel with powder coatings. But I do not know how to prevent the powder coating to be peeled afterwards. Can anybody help me to make a chemical procedure before painting the galvanized surfaces.
Zlen Petmezciler
- ISTANBUL, Turkey
Before applying powder coating, make sure that the surface has been properly prepared: i.e., remove all superficial impurities from the surface, etch the surface, chromate-coat the surface, make sure that the surface is bone-dry, and apply the powder coating, heating it to the temperature and duration recommended by the powder manufacturer.
Pre-treatment process effective at around 25 to 40 °C are available.
S. MEENAKSHISUNDARAM
- CHENNAI, TAMIL NADU, INDIA
June 1, 2009
Hi, Zlen. While chromate conversion coating of the galvanized surface can be done, I believe that the best way to prepare galvanizing for powder coating is to zinc phosphatize it. If you patiently search the site for "galvanize powder phosphate" you will find a number of helpful threads. Good luck.
