Density of copper & zinc
United States Mint image
What is the density of copper? Also what is the density of zinc?
Flo M [last name deleted for privacy by Editor]- Poughkeepsie, New York
When you go to search for density of materials, do not forget to also search "specific gravity".
Ira Donovan, M.S.F.Kansas City, Missouri
Bill Reynolds [deceased]
If you don't quite understand what density means, see the
"Coach's notes". Until 1982 pennies were made of copper; since 1983 they have been made of zinc with a thin copper plating - What is My Weight in Pennies? - A Penny's Worth of Copper, A Nickel's Worth of Nickel The chemical symbol for copper is Cu, and for zinc is Zn. A cooper makes wooden casks held together with bands of steel, not copper. |
"Hands-on" learning is fun, maybe try a ...
Precision Electronic Scale
on
Dude! That was so cool! Cause I had homework to find the density of those two elements and they are right there! Awesome! Who's getting an A? Me! Hurrah! Keep putting stuff like that up and I will pass Chem. for sure. Awesome!
Bob B.- Middlesex, New Jersey
You guys rock. Thanks for the easy source for my paper. :D
Rei C [last name deleted for privacy by Editor]January 22, 2009
Hi, puzzled, I was given to carry out an experiment to determine the density of coated cylindrical copper wire with the following data diameter 0.22 mm, length 197 cm and mass
0.6 g. The problem is that the answer should be almost the standard density of copper.
STUDENT - LUSAKA, ZAMBIA
January 28, 2009
Hi, Teddy. That sounds like a calculation, a homework question, not an experiment. What part of the experiment did you actually do -- measure and weigh the copper? The answer is not off by a lot (less than 10 percent). Show your work and we can point out the error if you made one. Thanks.
hi..
I want to ask.. what is the relation between material thickness and density?
material is stainless steel. the density is 7480 - 8000 kg/m3.
but, how to relate material thickness and the density..?
hope you can help me with this..
thank you
researcher - Malaysia
March 18, 2010
Hi, Aisyah. There is no direct relationship between thickness and density.
Thickness is one of the three dimensions. If you multiply the thickness X the length X the width you will have the volume of the item. If you multiply the volume X the density per unit volume you will have the mass (or weight) of the item.
March 2010
