Painting Aluminum Siding
I have a very small section of white aluminum siding on an otherwise brown house...it looks terrible but to have someone come in and change the white to brown is very costly. I have seen some postings that indicate that exterior latex paint applied to a cleaned surface should work o.k. My question: will sandpapering the surface improve adhesion or should I just wash and paint?
Lou Rishchynski
- Toronto, Ontario, Canada
"Siding: Step by Step Installation Techniques"
"Exterior Siding, Trim and Finishes"
I had the identical situation and I did exactly what you want to do. I simply washed the siding, and found that the adhesion was not perfect, but was good enough for a house. In other words, you could easily scrape the paint off with a coin if you tried, but there was no blistering. Sanding it is a lot of work and would seem to me to increase the susceptibility to corrosion.
Lou,
I like your idea of sandpapering as it will increase the surface area to be painted and gives a rougher finish for the paint to 'glue' to. Consider, too, pressure washing if you have a pressure washer.
Ordinary (outdoor) latex? Why not. You can always repaint BUT adhesion is important.
Take a gander at the 'next' inquiry #10494.
CHEERS!
freeman newton portrait
Freeman Newton [deceased]
What are the proper steps to paint an older home with aluminum siding? I also need to know the type of paint that should be used.
Dennis Beam
homeowner - Marion, North Carolina, America
