Cleaning surfaces after Alodine plating is done
We use a light, clear coating of Alodine (MIL-C-5541) on our electronic enclosures. What is the best way to clean the enclosure surfaces after plating and not harm the plating itself? Mild soap and water? Alcohol?
Dave Banasek
computer group - Tempe, Arizona, USA
What are you trying to clean from the surface of the parts. If it is organic in nature such as finger prints, oil, etc. I recommend that you wipe them down with IPA (or immerse). Be careful if you attempt to use "soap' as any cleaner containing sodium hydroxide specifically will attack and remove the chem film coating.
Hope this helps.
Timothy D. McCray
- Phoenix, Arizona
