Field finishing a new bronze door
Incralac
(brass lacquer with benzotriazole)
Q. What should I use to 'finish' a brand new bronze (CDA 385) door/entry set? I've been told to clean it first with Brass-o, then apply 3 coats of Incralac [on eBay or Amazon (adv.)] . Suggestions?
Thomas U. [last name deleted for privacy by Editor]
- Mobridge, South Dakota
A. Dear Thomas,
Since the doors are brand new, did the manufacturer already apply a clear coat? Check with them and see, if so, you should be okay for awhile. If not, Brasso [on eBay or Amazon (adv.)] or another polishing compound would work fine, but before applying the clear coating, you need to chemically clean (acetone [on eBay or Amazon (adv.)]) the door and remove all traces of the polishing compound. I think Incralac [on eBay or Amazon (adv.)] is an acrylic lacquer, this would not last too well on areas that will be handled, such as doorknobs or pulls. A nitrocellulose lacquer sprayed as a base coat and then top coated with the acrylic lacquer would give you the best durability there.
Good luck,
Jake Koch
G. J. Nikolas &Co.,Inc.
Bellwood, Illinois
nikolas banner ad
thumbs up signHey Thomas, How is your brass looking? Just ran across this post.
Dave Nowlan
- cotopaxi, Colorado usa
April 3, 2014
