Teflon Non-Stick Cookware Repair Spray to Fix Pots & Pans
< Prev. page (You're on the last page of the thread)
Sorry, non-stick repair spray for pots & pans seems to no longer be available; but please feel free to read and comment!
! These sprays are discontinued for a reason. PTFE becomes a highly poisonous gas when heated above 500 degrees. It can kill within minutes if exposure is high. Even with relatively small exposure, it causes neurological damage. It is FDA approved as a cookware coating only when used properly, and under conditions where the temperature would not likely exceed it's melting point. The few dollars you would save by re-coating your cookware is simply not worth it. Just buy a new one, or better yet, get old-fashioned iron pots and pans and season them thoroughly with lard. It will have the same effect without the health hazard. Kagan Hudayar- White Plains, New York January 21, 2010 ---- ! The use of a PTFE repair spray is dangerous and should be avoided. It emits over a dozen toxic gases when heated over 500 °F. Instructions that suggest spraying and baking in a 550 °F oven are negligent. - Epping, New Hampshire February 20, 2010 ---- April 25, 2012 A. Response to Peter G. "Non-Stick Cookware Repair And Coating Instantly Creates A Non-Stick Surface" - Ruston, Louisiana ---- !! I have worked with fluoropolymers for a number of years, ran two test labs and have done research. The comments about poisonous gas are extremely inflammatory and have no business on this site. For one thing, PTFE does not melt, it goes to a gel state. PFA and FEP are melt processable. PTFE is rated for use at the 500 °F range, that is why it is used for the covering on aircraft and spacecraft wire. DuPont sells PTFE spray-on coatings for industrial and commercial use that are baked on at temperatures well above 500 °F. The temperatures used to process PTFE from its powder form into products such as tubing run into the 1100 °F range. The PTFE fever mentioned has to do with raw PTFE (unprocessed) along with the lubricant used to bind the powder together in order to extrude the PTFE during its processing. It is unfortunate that mis-information is given on the internet. Gerald Brickert- Fort Worth, Texas April 30, 2010 ---- A. I have a friend who lives in Spring Grove, IL. He left a teflon coated pot too close to a range burner which he left on. - Zion, Illinois January 23, 2011 June 26, 2012 A. I've had Exotic Birds (spoiled rotten at that) for many years while caring for a very needy Geriatric person. Maker of Artisanal Hand Crafted Soaps - San Antonio, Texas, USA |
A. I did find the spray available, but it looks like it only ships in Europe. I am considering having a friend order it and ship it to me in the US.
www.buyasyoufly.com/2537/product_detail.html
- Thornton, Colorado USA
December 6, 2010
flyasyoubuy is out of stock and has no info on when it will be back in stock
marta young- rush, dublin, ireland
June 18, 2011
A. While searching for a non-stick cookware repair spray I ran across your forum. I did find some for sale on buyasyoufly.com/2537/product_detail.html but I also wrote to Dupont asking if they made a product like that and received the following reply:
Thank you for your inquiry. Due to the substrate preparation, baking/layering/spraying application and curing process that is required to apply DuPont nonstick coatings to cookware and household appliances, DuPont is not able to manufacture "spray on" Teflon® coating. We do not offer or recommend a service to re-coat cookware or household appliances. . . "
- Belton, Texas, USA
March 29, 2011
Ed. note: Thanks Lee. But the spray you mention has no Teflon, indeed no PTFE at all, in it.
No! No! No! Brownells sells teflon spray coating for gun products to reduce carbon buildup. I don't know if that helps anyone.. Ed Watson- Louisville, Kentucky USA February 2, 2012 ---- |
Q. I work for a timeshare we have non-stick teflon pans. Always having to replace them, very costly -- want to know can I redo the pans, what do I use, and would this be cost effective?
tammy depew- st pete florida
May 26, 2013
Q. Question:
I have read all previous questions and answers which all indicate that a non-stick repair spray for kitchen pans is no longer available anywhere.
About 6 years ago I purchased 3 spray cans of a product and used almost one which left the other two stored in a kitchen drawer. I recently found need for the product on a electric grill but when I went to retrieve, I found my son had cleaned out the drawer and tossed it out.
This was a great product and provided long lasting service. I find it inconceivable that it is no longer carried by anyone.
Why was this taken off the market?
- Buffalo, New York, USA
July 2, 2013
A. Hi Paul. I don't know whether the product was "safe" (which is a relative term) or not. But sometimes it is just not possible to prove the safety of a product to a degree that satisfies the regulators and to where the risk of lawsuits is low enough. We live in an extremely risk-averse and highly litigious age, utterly different from when I was young. Products which were considered a great idea 25 years ago are often now considered just too risky to market. Changing times is my guess why no one is willing offer a repair spray of this type anymore.
July 2, 2013
On the subject of non-stick repair spray, is the fact that you can't buy it maybe because by repairing pots and pans you seriously hurt sales of cookware? Planned Obsolescence!
James Tuck- St Cloud, Florida, USA
October 5, 2013
Ed. note: You have your theory, we have ours. Aloha.
That's the same conclusion I came to, whatever would happen if we could repair our pans. Think Stainless is the way forward ;-/
Sue Foster- Dorset, UK
October 22, 2013
December 2013
Hi James; hi Sue. You can try www.buyasyoufly.com/2537/product_detail.html as that page claims to sell it. But based on all the tail chasing in the previous postings, it certainly won't surprise me if they don't :-)
Ed. note Apr. '17: That page is now an "Error 404, Unable to Find".
A. http://www.buyasyoufly.com/2537/product_detail.html
As of this post it is available to ship in EU only.
http://www.intechservices.com/DuPont-Teflon-Coatings/How-to-Purchase
The second link requires you to submit a questionnaire for their review to determine if they will sell it to you.
Hope this helps. I'm going to have a friend in EU purchase and send to me as others have suggested.
- Florence, Arizona, USA
January 22, 2014
January 24, 2014
Thanks Kelea! The only clarification that I would offer is that the two links you posted have nothing to do with each other. The first link is to a product that is not and does not Teflon, and has nothing to do with DuPont. The second is to DuPont, who has already made it clear that they offer no such consumer product.
Here's the solution people.
- Oporto, Portugal
April 20, 2016
Q. Six weeks after it was posted, the link to BuyAsYouFly.com doesn't work. In fact, the whole domain doesn't respond. The earlier posting implies that Ted Mooney was able to view the product in late April, but it's not working for me today. Any other ideas on finding this product?
Vere Nekoninda- Albuquerque, New Mexico USA
June 8, 2016
Hi Vere. It's time to stop looking for it folks!
As reported above, it was discontinued by the manufacturer at least 6 years ago. I'd guess that buyasyoufly either acquired a stock of it at different times or suffered a computer glitch that made it sound recently available when it actually wasn't. But I personally wouldn't put something onto cooking pans when the manufacturer decided to stop offering it many years ago.
June 2016
Q. I have a propane big griddle; surface is steel, would like some kind of coating such as Teflon. Is there any product to use?
diane fields- middletown Ohio usa
April 15, 2017
A. Hi Diane. There is nothing you can do yourself, but if money is not tight it is probably possible to send the griddle out for ceramic/porcelain coating.
April 2017
For those who can't get enough of a topic, see also letter 12601, "Need Teflon Spray Can for Home Cooking Pans/Pots".
